PCM for 2005 4.0l - JeepForum.com
post #1 of 6 Old 06-08-2019, 06:53 AM Thread Starter
cushmanMLB
PCM for 2005 4.0l
I'm fairly certain I blew my computer when jump starting another vehicle. Jeep has been running very erratic. Stalls out. Some mornings it will show six codes, others it will be as many as 11. Sometimes it'll run normal and the engine light will shut off for the rest of the commute.
Some of the codes are related to the PCM. Some are related to the IAC. And other random ones.
Is there a place online to buy a used one cheaper than retail? And if so, will it already be programmed?
cushmanMLB is offline
post #2 of 6 Old 06-08-2019, 07:08 AM
dbbd1
dbbd1's Avatar
There is this guy...
http://wranglerfix.com/news/
But, they all (of the rebuilders and such) have mixed reviews. The guy above is fairly new to the scene. Call and ask for a forum discount.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #3 of 6 Old 06-08-2019, 07:17 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the engine runs, and you can drive the Jeep, PCM failure is not very likely.
The first thing to do is buy, borrow, or rent an OBD-II trouble coder reader and download all the Check Engine Light trouble codes. Then decipher them. You will likely see a common thread to the primary cause of the trouble codes by comparing the listed possible causes for each individual code. Post the exact trouble codes by the numbers here for comment by other JeepForum members.
One might more likely suppose that you; blew a fuse, damaged an OBD-II engine management sensor, or possibly melted a wire and have a short circuit.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 6 Old 06-08-2019, 12:20 PM
rcroane
Manual or automatic? If auto, are you getting P0218 or P0714 codes?
You’ll need a scanner that can read transmission codes to see those.
rcroane is offline
post #5 of 6 Old 06-08-2019, 04:27 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
If it's an auto, shoot it now!
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #6 of 6 Old 06-09-2019, 10:11 PM
bonza
out of curiosity but what makes you think doing this blew your Jeep's computer? did you put the leads on back to front or similar?
I've used my Jeep to jump start several other vehicles with no issues
2005 TJ Light Khaki
bonza is offline
