Passenger Footwell Leak - JeepForum.com
post #1 of 10 Old 06-03-2006, 09:40 PM Thread Starter
halfmoonclip
Okay, tried search, I must not be asking the right questions.
Here's the deal; when the Jeep sits down at the cabin in the rain, I find some water (not a lot) in the passenger footwell. Often the Jeep is sitting with the pass side higher.
I haven't noticed any leakage when I'm driving.
The drain behind the engine seems to be clear; ran the hose down the cowl intake, and water came out promptly under the Jeep. No water in the footwell.
So what do ya' think?
Thnx,
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
post #2 of 10 Old 06-03-2006, 10:38 PM
trivergata
Guest
I've been told this is a leak in the windshield frame gasket - mine started after I took down the windshield once. Supposedly putting a bit of sealant on the gasket (when it's down) and then bolting up the frame again will do it, but mine's not too bad, and after all, it's a JEEP - wet carpet comes standard.
Josh
trivergata is offline
post #3 of 10 Old 06-07-2006, 12:19 PM
quigtj
Watch the playoffs!
Same thing Here
Got in the Jeep after parking it in the rain (hard top on - just picked it up)...pulled my backpack off the floor and there was an inch or more of water.
Later, after another couple of hours of it sitting in a down pour, I pull out of a spot, turn right, and all this water seems to come out from beneath the dash...Is this the engine drain thing you are talking about? I'll have to look around...
Let me know what you figure out.
quigtj is offline
post #4 of 10 Old 06-07-2006, 01:57 PM
scorpionkill
scorpionkill's Avatar
I had the same thing the other day, heavy rain= water on passenger side, was actually dripping from under the dash. Wonder about the cowl
2008 JK X 2 door, 1997 TJ
scorpionkill is offline
post #5 of 10 Old 06-07-2006, 05:55 PM Thread Starter
halfmoonclip
I think there are actually a couple issues here, the plenum under the cowl leak being just one.
Don't think that is my problem. Mine doesn't leak when driving, but if I'm parked with the passenger side slightly UPHILL it leaks from the bottom of the door.
The soft top seems to put a steady run of water down the window about 1/3 of the way back from the A pillar; suspect that may be the culprit. Don't remember it ever happening with the hardtop/rain gutters in place.
In any case, for the moment the slop mats catch it, so what the hell. I would like to fix it eventually.
Moon
post #6 of 10 Old 06-07-2006, 06:39 PM
Bishop Creek
Bishop Creek's Avatar
Whenever it rained or I washed my rig, I always found a puddle of water on the passenger side floorboard with my hard top on, but since I removed it and put a soft top on no more leaks of any kind.
ďThis isnít the Old West, because the New West has never arrived. Itís just the West, like Wyatt Earp died yesterday.Ē
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #7 of 10 Old 06-07-2006, 07:55 PM
TransRV
TransRV's Avatar
I've got the same issue, so keep this going...?
TransRV is offline
post #8 of 10 Old 06-07-2006, 08:35 PM Thread Starter
halfmoonclip
We all have the PROBLEM but not the FIX...
Moon
post #9 of 10 Old 06-07-2006, 08:40 PM
Supercharged99TJ
Guest
Leak
I went through this leak a while back. It took the dealer over a month to finally find and fix it. After a rain, the passenger floorboard would be 1" or better deep with water. They replaced every gasket on the Jeep and it still leaked. They took the entire dash out to see where the water was coming from. It was coming from the gasket under the windshield which is between the windshield frame and the body. They told me that from the factory, the gasket was installed improperly and water was running through a factory hole in the windshield framing. They put a new gasket on and it hasn't leaked a drop since....
Supercharged99TJ is offline
post #10 of 10 Old 06-08-2006, 12:47 AM
TransRV
TransRV's Avatar
hmmmmmm??? This sounds like something I may want fixed...
TransRV is offline
Passenger footwell light estoddart TJ Wrangler Technical Forum 3 05-16-2009 04:38 PM
Passenger side leak?? mpo JK Wrangler Technical Forum 1 12-17-2008 05:58 PM
Leak in the passenger side baseballcaz TJ Wrangler Technical Forum 2 12-02-2008 05:20 PM
coolant leaking into passenger footwell 1993yjgreen YJ Wrangler Technical Forum 6 02-27-2006 06:21 AM
Passenger Side Leak?? Dirky TJ Wrangler Technical Forum 2 08-06-2003 12:02 AM
