P0431 Code? - JeepForum.com
post #1 of 43 Old 09-13-2011, 02:34 PM Thread Starter
2005-TJ
1983 CJ7
P0431 Code?
I just got a check engine light today for a P0431...does anyone know what this is and what needs to be done to fix it? I have an 05 TJ with 70K on it.
2005-TJ is offline
post #2 of 43 Old 09-13-2011, 03:03 PM
flying_bosun
flying_bosun's Avatar
That's indicating a bad O2 sensor ("warm up catalyst below efficiency threshold"), but it's probably a bad catalytic converter, I think. If it's the cat, it's covered by 8/80 federal emissions warranty. Had the same problem, swapped out O2's twice, then had the cats replaced (one was hollow) by the dealer at no charge. Code's gone and fuel economy is up.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3 of 43 Old 09-13-2011, 03:16 PM Thread Starter
2005-TJ
1983 CJ7
is there anyway for me to check if it is the cat?
2005-TJ is offline
post #4 of 43 Old 09-13-2011, 03:17 PM Thread Starter
2005-TJ
1983 CJ7
also how do i know which one?
2005-TJ is offline
post #5 of 43 Old 09-13-2011, 03:29 PM
flying_bosun
0431 is bank 2, which I think is the rear, but I can't swear to it. Some say you can hear if it's hollow or if the honey-comb is crumbled by tapping on it with a wrench or other "tapping devise". Worst case, unbolt it and have a look? I didn't even bother; after replacing the O2 a second time, I "knew" it was the cat and had the entire system between the manifolds and the muffler replaced when I replaced my cam.
― Ron Paul
post #6 of 43 Old 09-13-2011, 03:38 PM Thread Starter
2005-TJ
1983 CJ7
The cat is covered under factory warranty for 8 yrs or 80k miles?
2005-TJ is offline
post #7 of 43 Old 09-13-2011, 03:46 PM
flying_bosun
Federal Law says so.
― Ron Paul
post #8 of 43 Old 09-13-2011, 03:48 PM Thread Starter
2005-TJ
1983 CJ7
This might also explain my horrible fuel mileage...i only got 175 miles out of my last tank of gas
2005-TJ is offline
post #9 of 43 Old 09-13-2011, 04:48 PM Thread Starter
2005-TJ
1983 CJ7
my buddy is coming over with a good snap-on scanner...is there a way for me to monitor and determine if it is the cat or an o2 sensor?
2005-TJ is offline
post #10 of 43 Old 09-13-2011, 05:01 PM
flying_bosun
Yes, I could.
Not that I'm aware of. There may be a way to meter the leads on the O2 sensors, but you'd have to search for that. I've seen it discussed here in Tech, but couldn't begin to tell you where, exactly.
― Ron Paul
post #11 of 43 Old 09-13-2011, 05:27 PM Thread Starter
2005-TJ
1983 CJ7
not that i really know what i was looking at but all 4 sensors seemed to be in roughly the same range on the Snap-on Ethos scanner...i reset the CEL and it hasn't come back on yet.
2005-TJ is offline
post #12 of 43 Old 09-13-2011, 05:38 PM
flying_bosun
That says to me that it's a cat.
I've got my fingers crossed for you, but give it about 60-75 miles of driving before you start holding your breath. With the recent drop in fuel economy you mentioned, I'd hedge my bets.
― Ron Paul
post #13 of 43 Old 09-13-2011, 05:45 PM Thread Starter
2005-TJ
1983 CJ7
thanks for your help
2005-TJ is offline
post #14 of 43 Old 09-13-2011, 07:15 PM
JPNinPA
P0431 is Bank 2 sensor 2. That is the last three cylinders before the firewall and the O2 below the cat.
1) If you pull the O2 and it looks flattened on one side your cat is on it's way out. Being all 4 O2's are switching the same the front three cylinders may be bad as well.
2) You could have a exhaust leak post the first O2.
3) Bad O2 sensor.
Since you reset the CEL it may take 4 days to come back.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #15 of 43 Old 09-13-2011, 07:24 PM
flying_bosun
3) Bad O2 sensor.
My O2 sensors looked normal with no flattening and the cat was GONE. Not saying you're mistaken at all, just sayin'.
Could you clarify what you mean by "Being all 4 O2's are switching the same the front three cylinders may be bad as well."?
― Ron Paul
Engine light came on, pulled code- p0431 gebirgziege TJ Wrangler Technical Forum 49 03-24-2013 06:03 PM
OBD code p0431 Warm up catalyst below threshold??? Spinny TJ Wrangler Technical Forum 21 01-02-2013 08:32 PM
P0431 Code-Harmful? Jbecker TJ Wrangler Technical Forum 0 02-11-2011 02:00 PM
P0431 is the code it gave. Futhy TJ Wrangler Technical Forum 10 03-08-2007 11:55 AM
