Optima battery flat dead - JeepForum.com
post #1 of 128 Old 12-19-2010, 10:58 AM Thread Starter
dadscab
Well this is the second Optima battery to go flat dead without any warnings. It was the red top and around 4 years old? No signs of it dying just would not start or even turn on lights. What is a good replacement battery for the TJ that is maintenance free???
dadscab is offline
post #2 of 128 Old 12-19-2010, 11:01 AM
jeepinmichguy_
jeepinmichguy_'s Avatar
Most people are switching to the sears die hard platinum 34/78. I have yet to have the optima issues that others are having. Good luck.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #3 of 128 Old 12-19-2010, 11:06 AM
chris142
Are you sure that nothing got left on and drained it? Have you tried hooking it to another charged battery then hooking your charger to them to get it going?
chris142 is offline
post #4 of 128 Old 12-19-2010, 11:07 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
go with a Diehard Platinum P4
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 128 Old 12-19-2010, 11:10 AM Thread Starter
dadscab
Was working out at the desert yesterday and shut the jeep off for about 10 mins. Went to start it and nothing. Off road lights, radio, gauges, nothing. Checked the terminals and they were clean. Had to jump start it to get it to run then while driving home the alternator would charge up to 19 amps while under high RPMs. Let it idle for a second and would go back to normal around 14 volts
dadscab is offline
post #6 of 128 Old 12-19-2010, 11:35 AM
del_TJ
del_TJ's Avatar
My first optima red top only lasted 3 years. I'm 1-1/2 years into my second red top but when I bought it, I didn't realized that people are saying the quality of the optima batteries isn't what it used to be. It made me think that the short 3 year life wasn't just a fluke. I'll go with the Sears Platinum next time based on the positive feedback.
del_TJ is offline
post #7 of 128 Old 12-19-2010, 11:55 AM
Boundless
Boundless's Avatar
what he ^ said X's...
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #8 of 128 Old 12-19-2010, 12:01 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
Ditto. I love mine. The only time it ever gave me trouble was when I rolled my jeep and had to jump it. Otherwise it's been great even on the coldest days.
Recoil is offline
post #9 of 128 Old 12-19-2010, 12:34 PM Thread Starter
dadscab
Thanks Guys! I will go Sears today and pick one up. Ive gone through two Optimas now. One in my sand rail and now one in the jeep so I am now officially out of the Optima fan club. Both times left me stranded in the desert..
dadscab is offline
post #10 of 128 Old 12-19-2010, 12:56 PM
asknight
asknight's Avatar
East Penn Deka Intimidator 34/78
O'reillys sells it as a Super Start Extreme AGM 34/78.
asknight is offline
post #11 of 128 Old 12-19-2010, 02:24 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You can add your woes if you're so inclined. Essentially though, the party line from Optima via Optima Jim is if your Optima dies, it's your fault for putting a non deep cycle battery (Red Top) into deep cycle useage. Nor does it matter that you've since replaced it with the cheapest flooded cell SLI you can buy and the only change to the system or useage is swapping batteries.
Batteries...Optima alternatives? - Pirate4x4.Com Bulletin Board
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #12 of 128 Old 12-19-2010, 02:26 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Do any of the O'reillys affiliates honor their warranty? The reason I ask is we do not have that brand of store here in the west that I know of and I do know we have Sears stores nationwide.
I am Savvy
mrblaine is offline
post #13 of 128 Old 12-19-2010, 03:33 PM
dcope17
dcope17's Avatar
This is a problem... I assume you mean 19 volts. You should never get more than 16V... Possibly overcharging damage from a bad voltage regulator?????
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #14 of 128 Old 12-19-2010, 04:53 PM
tangotag
I checked with my local O'Reillys, they do honor the 3 year free replacement then out 84(I assume remaining 48) month pro-rated.
But they can't recall any returns on the East Penn's Deka AGM at least in the last 2 years.
They don't push the AGMs for sales, and do explain that they sell less expensive conventional batteries and want the customer satisfied. O'Reillys offered to test my current battery for free to make sure it needs replacing.
tangotag is offline
post #15 of 128 Old 12-19-2010, 05:15 PM
flatlander757
flatlander757's Avatar
You can buy that same battery at any Carquest store as well, though it is under the "NGT Extreme" name... it's a rebadged Deka Intimidator.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
Dead Battery, replacing with Optima Yellowtop yelset TJ Wrangler Technical Forum 38 07-21-2010 11:49 PM
00 TJ 4.0, dead Optima won't charge, push start? jage TJ Wrangler Technical Forum 10 12-10-2009 03:46 PM
battery dead ....argh... dual battery setup???? asjeep TJ Wrangler Technical Forum 21 07-20-2009 06:46 AM
Which Optima Battery? sknowskier YJ Wrangler Technical Forum 17 08-07-2008 01:42 PM
optima battery 04skizJ TJ Wrangler Technical Forum 14 04-25-2006 06:55 AM
