OPDA - JeepForum.com
post #1 of 5 Old 12-11-2019, 06:24 AM Thread Starter
40vern
OPDA
what is opda? i have been reading allot of different things on this forum. since i started up my motor yesterday and let it run for the first time i have some questions.
the motor temperature gauge never did so it running hot but i did notice that the exhaust manifold started to turn a little red so i shut it down.
i have had this happen before on my old 22re yota motor.
i had advanced the timing on that motor and i new how to correct this easy.
so i have been searching this forum for timing. i keep reading opda and dont know what this is?
also i dont have anything hooked up to this motor yet.
the air box is still off.
the cannister is off.
and the vent tube that runs from the fuel tank beside the fuel line is still off.
i assume these things will make it run differently too.
40vern is offline
post #2 of 5 Old 12-11-2019, 06:52 AM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
This is just a SWAG-----oil pump drive assy ??
BlueFl.Wrangler is online now
post #3 of 5 Old 12-11-2019, 09:35 AM
jtec
jtec's Avatar
2014 JK Wrangler
OPDA= oil pump drive assembly
you cannot set or adjust engine timing.
Do NOT move OPDA, dont touch it, don't look at it, nothing good will come of that.
You vehicle has a great diagnostic computer.
jtec is offline
post #4 of 5 Old 12-11-2019, 11:51 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Yes, oil pump drive assembly. It is where the distributor would be on earlier versions of the 4.0L engine & also has the cam sensor under the cap. If you have a distributor (pre 2000 TJ) you do not have one, the distributor also drives the oil pump.
On any TJ the ignition timing is controlled by the PCM & not adjustable.
It sounds like the engine is running lean, not a timing issue.
Hooking everything up might help. Also check for a vacuum leak, especially if it is idling high.
Rubi4MyMrs is online now
post #5 of 5 Old 12-11-2019, 04:36 PM Thread Starter
40vern
thanks
been hooking everything up. the cruise control thing has the charcoal thing i think and the washer fluid canister. several vac lines. going to hook the breather box now
40vern is offline
