OME 2” lift with 33s question - JeepForum.com
 13Likes
post #1 of 26 Old 06-04-2019, 11:20 AM Thread Starter
Brewski80
Brewski80's Avatar
I just purchased the HD OME 2” lift for my 01’ wrangler and I have a set of tires I took off my truck last year that are 33s. I would really like to use them on the Jeep. My question to y’all is should I order different fenders or just order a 1” body lift so the tires don’t rub? I’m a noob when it comes to this stuff. I will post a picture of the tires I want to add. I don’t think they’re true 33s. Thanks fellas
Sent from my iPhone using Tapatalk
Brewski80 is offline
post #2 of 26 Old 06-04-2019, 12:16 PM
JeffBowser
JeffBowser's Avatar
I've run that combo for 15 years, plus (I run 33x11 equivalent). A 1" BL is pretty much a must. On my particular Jeep, I also had to add a couple of washers to my steering stops to prevent rub on the control arms at flex and lock.
Ross, Ironhead and Brewski80 like this.
JeffBowser is offline
post #3 of 26 Old 06-04-2019, 05:05 PM
KRV
KRV's Avatar
I run 33” Mud Terrain tires with a 2” budget boost. Rubs at full turn, but I never do a full turn. You’ll be fine.
Brewski80 likes this.
KRV is offline
post #4 of 26 Old 06-04-2019, 07:13 PM
biffgnar
biffgnar's Avatar
You'll need the BL and probably will still need to adjust bumpstops. 33s really needs 3" of suspension lift to maximize performance.
Ross and Brewski80 like this.
biffgnar is offline
post #5 of 26 Old 06-05-2019, 08:31 AM
Goatman#1
I think you will find the vast majority of folks here will say the body lift. Just remember there is more to a body lift than just some aluminum pucks. But it seems to help with a lot more than just tires.
Goatman#1 is offline
post #6 of 26 Old 06-05-2019, 05:58 PM
Neener Neener
Neener Neener's Avatar
You'll need at least 1" of lift. My previous TJ had an OME 2" lift and 33's and required it. That's a great lift, btw.
There are no stupid questions, only stupid people.
Originally Posted by Al The Killer
My monkey likes your monkey
Originally Posted by Grape Ape
Just go get one and lick it when you get the urge.
Neener Neener is offline
post #7 of 26 Old 06-06-2019, 07:37 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Not much.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Originally Posted by Jerry Bransford View Post
I'd rather knock myself unconscious, cut a finger off, poke my eye out with a sharp stick or be forced to go back to work than install anything made by Rusty's.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ on 33s.
TheBoogieman is offline
post #8 of 26 Old 06-06-2019, 07:51 AM
Goatman#1
What do you need then? I thought you would need a motor mount lift, granny mount lift, a transfer cable shift, and a few more little things.
post #9 of 26 Old 06-06-2019, 07:58 AM
Duck Doctor
None of those items are required for a body lift. Adjusting the fan shrouds negates the MML. Never heard of a tranny mount lift. Transfer case linkage can be adjusted so a cable shifter is not required.
Duck Doctor is offline
post #10 of 26 Old 06-06-2019, 08:33 AM
TheBoogieman
Distubed Jeepaholic
It's never taken me more than an hour to install one. Well, maybe 2 hours the first time with rust. There's a few unnecessary steps in most BL instructions.
http://www.4x4xplor.com/bl.html
99' XJ on 33s.
post #11 of 26 Old 06-06-2019, 11:46 AM
03Blubicon
03Blubicon's Avatar
Been my setup for a long time. I installed a MML because of my long term plan. It helps if you know what future mods will be when starting out.
I run 33x10.50s and only needed a lock washer behind the steering stops.
03Blubicon is offline
post #12 of 26 Old 06-07-2019, 07:11 AM
Goatman#1
Well, hell. I stand corrected. No wonder everyone says this is the way to do it. I've been on the fence about 33"s because I didnt want to have to redo the spring lift. So you would do this over a 1" coil spacer pick lift?
post #13 of 26 Old 06-07-2019, 11:42 AM
03Blubicon
03Blubicon's Avatar
In my opinion, if you want to run a 33, the OME with a 1.25 BL is the way to go. As stated earlier, you really need a solid 3" of lift to take advantage of 33's. Run a 2" bump stop and you should be good.
A non- Rubicon will need a SYE and CV driveshaft and will benefit from a 1" motor mount lift. My Rubicon ran for several years with the stock control arms, angles, and drive shaft.
Obviously, this is much more pricey than a 2" spacer. Only you can decide what you want from your rig.
For these setups as a package, Dirk at DPG Offroad is very helpful, and great to deal with.
post #14 of 26 Old 06-07-2019, 01:36 PM
Needalife
A non-rubicon will not need a SYE and CV driveshaft or better yet 99% will not need them for 2.5"/3" of lift. I say that as every Jeep is different.
Run the OME lift and add 1" body. You will be more than fine for 33" tires. I would recommend that you do a 1" mm also just to help driveline
Jeeps, We like it dirty, rough, and wet!
Needalife is offline
post #15 of 26 Old 06-07-2019, 04:30 PM
biffgnar
biffgnar's Avatar
I don't agree with this. Yes, it can vary but at 3" a lot more will require than don't. Even at 2" I bet it is an issue more than 1% of the time.
biffgnar is offline
