Oil pressure guage - JeepForum.com
post #1 of 9 Old 01-27-2011, 01:21 PM Thread Starter
fang_x
fang_x's Avatar
Oil pressure guage
Recently my oil pressure gauge has been acting up. During idle it will hover in its normal position and for most of my regular driving too.
But when I come to a stop and then accelerate, the pressure guage drops to 0 and the check guages light comes on. it then goes back up to normal.
Ive read a bit and there's two options i have, to either install a mechanical gauge to verify its not a major issue, or replace the sending unit.
can anyone give me more info on this? or has anyone had similar problems?
thanks
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #2 of 9 Old 01-27-2011, 01:22 PM
JBTJ
JBTJ's Avatar
I would do exactly what you said you need to do. Mine turned out to be the sending unit.
JBTJ is offline
post #3 of 9 Old 01-27-2011, 01:23 PM
freeskier93
The dash gauge is a "dummy" gauge. It's just there to show fluctuation or drop to 0 when a problem is detected. Hook a mechanical gauge up to verify. Most likely the pressure sending unit needs to be replaced.
freeskier93 is offline
post #4 of 9 Old 01-27-2011, 02:01 PM
Max-Q
1983 CJ7
Mine has doing that for years. It seems to be very common with the '97 TJ's but I guess yours is close enough. It's the oil sending unit. Your oil pressure is probably fine.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #5 of 9 Old 01-27-2011, 07:56 PM
slafferty
slafferty's Avatar
mine has been running a 0 for the last few months.. If it was true i'm sure the jeep wouldnt be runnin
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #6 of 9 Old 01-27-2011, 10:20 PM Thread Starter
fang_x
fang_x's Avatar
is there a write up of how to install a mechanical gauge? wouldn't mind giving that a shot.
the jeep does have pretty decent mileage, at 200,000 kms or ~124,000 miles
how much does a new oil sending unit cost?
fang_x is offline
post #7 of 9 Old 01-30-2011, 10:59 PM
Jebenhack
Bump. I'm having a similar issue.
Jebenhack is offline
post #8 of 9 Old 01-31-2011, 12:23 AM Thread Starter
fang_x
fang_x's Avatar
im going to order a replacement sending unit tomorrow, gonna give it a go and let you know how it goes
fang_x is offline
post #9 of 9 Old 01-31-2011, 02:54 AM
mediumdaddy
Mine was acting strange as well. Replacing the sending unit was easy. Cost about 30 bucks if i remember right, and you literally unclip the wiring harness, unscrew the old one, screw in the new one, and hook up the wires. its that simple. BUT it didnt change one thing for me. gauge still doesnt work right, but if there really was no oil pressure, your jeep wouldnt last long, and it would be knocking like there was no tomorrow.
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
oil pressure guage....low johnroot01 YJ Wrangler Technical Forum 12 05-06-2009 08:11 AM
oil pressure guage baghdadman TJ Wrangler Technical Forum 1 02-08-2006 02:07 PM
Oil Pressure Guage Five.Ten TJ Wrangler Technical Forum 30 02-15-2005 09:59 PM
Oil Pressure guage yman2or YJ Wrangler Technical Forum 4 10-18-2003 07:33 PM
Oil pressure guage DrEvil TJ Wrangler Technical Forum 1 09-16-2003 11:45 AM
