Oil Pressure Gauge issues - JeepForum.com
post #1 of 18 Old 07-18-2010, 01:37 PM Thread Starter
jdub36
I did some searches and found a couple of topics on oil pressure gauge issues but I could not find anything exactly like the problem i am having. My Oil pressure gauge works fine at start up and while running from 25mph and up, but when i begin to brake as my speed drops so does my oil pressure. By the time i am at a complete stop my oil pressure gauge is at 0. I had the oil changed just a few hundred miles ago and oil level is fine. Just thought i would see if anyone has any ideas before i spend $40 on the oil pressure sensor. By the way this jeep is new to me, it is a 97 with 4.0 engine and 130,000 miles on it.
thanks,
jw
jdub36 is offline
post #2 of 18 Old 07-18-2010, 01:54 PM
gremlinsteve
gremlinsteve's Avatar
i added my own autometer full sweep gauge so i whats its really at. cost more than the stock sensor yes, but i like it better than nothing.
steve
gremlinsteve is offline
post #3 of 18 Old 07-18-2010, 01:55 PM
freeskier93
Isn't the oil pressure gauge just a dummy? I thought it was fake.
freeskier93 is offline
post #4 of 18 Old 07-18-2010, 01:58 PM Thread Starter
jdub36
the gauge bouncing around would not bother me that much except the check gauges light comes on and beeps every time i slow down and stop. So do you think that the oil pressure sensor is causing my issues?
jw
jdub36 is offline
post #5 of 18 Old 07-18-2010, 02:02 PM
gremlinsteve
hook up a mechanical gauge to the stock port...best way to know..if its reading low then you have an issue somewhere...if its reading normal then replace the sensor
steve
post #6 of 18 Old 07-18-2010, 02:03 PM Thread Starter
jdub36
is that something they sell at the autoparts store? If i go in there and tell them what i want are they going to look at me crazy?
thanks,
jw
jdub36 is offline
post #7 of 18 Old 07-18-2010, 02:05 PM
gremlinsteve
most parts stores have cheap-o oil pressure gauges yes.. in the aftermarket aisle.
steve
post #8 of 18 Old 07-18-2010, 02:12 PM Thread Starter
jdub36
one more question. By "stock port" do you mean to get a gauge that is threaded and screw it into the port where the stock oil pressure sensor screws in or am i way off?
jw
jdub36 is offline
post #9 of 18 Old 07-18-2010, 02:20 PM
gremlinsteve
yep. if you buy that cheapo oil pressure gauge from the parts store it will have the adapters ect in it that will allow you to screw into that 1/8th npt threaded hole on the block. unscrew the stock sending unit and screw the fittings in..connect the gauge and see what its doing.
steve
post #10 of 18 Old 07-18-2010, 02:34 PM Thread Starter
jdub36
got it, ok i will give it a shot and see. So i guess i will have to drive with it on there and then hop out and open the hood and see what it says. It seems like it is reading ok at start up and idle, it just goes crazy after i drive for awhile and then stop.
jw
jdub36 is offline
post #11 of 18 Old 07-18-2010, 02:51 PM
gremlinsteve
should have enough hose in the kit to reach inside also
are you sure its not low on oil??
steve
post #12 of 18 Old 07-18-2010, 02:58 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
A dummy? No,it just doesn't display that accurately! I would suggest maybe first hooking it up to a manual gauge to check the pressure.It's probably in need of hopefully just a new oil sensor!Then again... how many miles on engine?Possible oil pump, bearings,etc.
GOLENJEEPTJ is offline
post #13 of 18 Old 07-18-2010, 03:05 PM Thread Starter
jdub36
i checked the oil it is full. I will grab a gauge and let you know how it works.
jw
jdub36 is offline
post #14 of 18 Old 07-18-2010, 03:11 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No, early TJ oil pressure gauges like from '97 to probably 2001 or so indicate the true oil pressure. It was after that when the programming was changed to only indicate mid-scale no matter what the engine rpms are so long as the true oil pressure (hidden from the driver) is ok.
So for the OP's and your '97, the gauge is accurate... at least it is if the oil pressure sender is ok.
Jdub36, a bad oil pressure sender is common in early TJs, I would change it and not install a second gauge. My '97 TJ's oil pressure sender went bad within its first two years.
Jerry Bransford is offline
post #15 of 18 Old 07-18-2010, 03:22 PM Thread Starter
jdub36
Thanks Jerry, I might just go ahead and swap it out. I hope that does the trick, after that the solutions seem to get way more complicated and expensive.
jw
jdub36 is offline
oil psi gauge
Possible to convert '03-'06 oil pressure gauge to display actual oil pressure? Night Wolf TJ Wrangler Technical Forum 40 05-03-2010 10:48 AM
Oil Pressure Gauge Issues jeepyjpsu YJ Wrangler Technical Forum 5 04-18-2008 07:42 PM
oil pressure gauge tazman61 TJ Wrangler Technical Forum 2 09-07-2007 08:03 PM
My oil pressure gauge is at '0' kchan156 TJ Wrangler Technical Forum 2 10-02-2005 01:02 PM
Oil Pressure Gauge and Fuel Gauge problems phattdraggon YJ Wrangler Technical Forum 5 05-11-2004 03:12 PM
