Oil Pressure - JeepForum.com
post #1 of 8 Old 07-21-2003, 08:09 AM Thread Starter
mking7
mking7's Avatar
Oil Pressure
Next time you crank up, can someone tell me how long it takes for your oil pressure to come up? I never looked until I changed my oil for the first time this weekend and it seems to take a while to come up (like 2 seconds or so). I am comparing it to my Ford truck and the Ford comes up much faster. Or at least it seems to.
Thanks,
2003 TJ and a bunch of crap bolted on........
mking7 is offline
post #2 of 8 Old 07-21-2003, 09:38 AM
Russ-68
Guest
That's about how long mine takes...
Russ-68 is offline
post #3 of 8 Old 07-21-2003, 10:28 AM
easttexan54
Guest
my oil pressure has been dropping below 20 sometimes lately..is there anything i need to check...besides my oil...
easttexan54 is offline
post #4 of 8 Old 07-21-2003, 02:07 PM
Dee Cue
Dee Cue's Avatar
Mine takes about 6 seconds to come up... Is this okay?
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #5 of 8 Old 07-24-2003, 01:54 PM
Firecat
Guest
mine does that exact same - it takes a few seconds for the pressure to come up. I know mine does dip a tad below 20 at time snad my engine on has 40k too. I think the manual states the 13 psi is satisfactory for the engine.
Firecat is offline
post #6 of 8 Old 07-24-2003, 03:16 PM Thread Starter
mking7
mking7's Avatar
When the engine is cold, it takes 2 seconds for oil pressure to START coming up. I would say 6 seconds is about what it takes for my oil pressure to come up to normal. If the engine is warm, the pressure comes up much faster since all the oil hasn't had time to drain back to the pan.
mking7 is offline
post #7 of 8 Old 07-28-2003, 09:01 PM
adiobulbu
Guest
factory gauges are not known for being the most accurate units out there. A good example is the fuel level gauge; say your tank is empty and you shut off the vehicle and fill the tank. You start it back up and the gauge sloooowly goes from empty to full. You know there is a full tank of gas but the gauge takes several seconds to register the change from empty to full. The oil pressure gauge is the same way. It is because they use an electrical sending unit just like the fuel level gauge. If you use a high quality mechanical gauge such as autometer you can start the engine and the gauge will snap to the pressure reading as soon as the pump starts building pressure. the only bad thing about the mechanical gauge is the install because you have to run a line carrying oil into the cockpit which really makes a mess if it ever develops a leak.
adiobulbu is offline
post #8 of 8 Old 07-29-2003, 06:31 AM
_RT_
_RT_'s Avatar
Another piece of information I found very interesting is the +/- that is "built in" to the guages now.
Apparently, customers would show up at dealerships saying the their battery guage was *slightly* below where it normally is, or their oil pressure guage doesn't seem to be consistent. This happened so many times, that the auto companies were wasting money trying to track down a problem that wasn't there.
Now it seems car companies (most of them) build there guages to just stay in the middle of display unless there is a large change. Most people feel comfortable when there guages are all dead center. They think that is the only place they should be.
-You're my boy blue!!!!
'79 CJ-5 - 304 V-8
'03 TJ Freedom - a little smaller
_RT_ is offline
Oil Pressure ? leaptj YJ Wrangler Technical Forum 15 05-09-2011 09:13 AM
Possible to convert '03-'06 oil pressure gauge to display actual oil pressure? Night Wolf TJ Wrangler Technical Forum 40 05-03-2010 10:48 AM
2.5L oil pressure 94mangler YJ Wrangler Technical Forum 9 04-30-2010 02:22 PM
oil pressure toates89 YJ Wrangler Technical Forum 2 04-30-2010 02:18 PM
Oil pressure LaJeeper TJ Wrangler Technical Forum 11 04-06-2006 08:58 PM
