Oil pan gasket question - JeepForum.com
post #1 of 4 Old 12-08-2019, 01:14 PM Thread Starter
Kristian_Burns
Hi all, I'm replacing the gasket on my oil pan and was screwing the bolts back in when I found this piece laying on the ground. Does this go towards the rear of the pan? I do not remember it falling.
Thank you
Kristian_Burns is offline
post #2 of 4 Old 12-08-2019, 02:06 PM
TJ4Jim
If I recall correctly that would be installed in the rear.
If you come to a fork in the road take it.
TJ4Jim is offline
post #3 of 4 Old 12-08-2019, 02:17 PM Thread Starter
Kristian_Burns
Thanks, between the gasket and the engine or vise versa?
post #4 of 4 Old 12-09-2019, 04:52 AM
Jonny Jeep
Jonny Jeep's Avatar
It goes on the outside of the pan. If you undo the two rear bolts you can fit it in place.
You can see it in this pic I found.
Jonny Jeep is offline
