Oil leak - JeepForum.com
post #1 of 3 Old 05-23-2019, 03:54 PM Thread Starter
Hunter121
Oil leak
I have oil leaking down the right side of my 4.0L inline six, it’s a 98’, The leak looks like it’s Coming from where the head meets the block. I was thinking my head gasket it bad, anyone have any other ideas?
Hunter121 is offline
post #2 of 3 Old 05-24-2019, 04:49 PM
JEK3
JEK3's Avatar
One common issue with the 4.0 is that the valve cover likes to loosen up, especially in the back. Tighten all the valve cover bolts, wipe off the oil from your engine, and observe for a couple of days.
JEK3 is offline
post #3 of 3 Old 05-25-2019, 08:05 AM
Goatman#1
Check where the oil filter ,or any other mounts. A messy filter removal can look like most any type of leak. I'd degrease the area or better yet the whole engine first, before you start to throw money at it to confirm where the oil is from. The previous mentioned valve cover can look like all sorts of different issues too.
Goatman#1 is offline
Major oil leak Hernando KL Cherokee 2014 & up 7 03-20-2019 09:22 AM
HELP! Massive oil leak 2.5 YJ Malenlie Engines & Drivetrain 2 03-16-2019 12:51 AM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
oil leak 2002 tj 4.0 jcrisp118 TJ Wrangler Technical Forum 5 07-28-2018 10:48 AM
Oil Leak 01saharatank Engines & Drivetrain 0 04-20-2018 11:32 AM
