oil filter question.... - JeepForum.com
post #1 of 10 Old 09-19-2014, 08:25 PM Thread Starter
coconut_pete
i have an '03 tj with a 4.0 the mobil oil filter that it calls for is an m1-204, however that one doesn't fit. i have to use the larger m1-209. anybody else have this issue? i have searched and searched to try to figure out how this could be with no luck. the number stamped on the passenger side of the block is 207mx16.
coconut_pete is offline
post #2 of 10 Old 09-19-2014, 08:42 PM
jkp
What do you mean it doesn't fit?
'92 Islander
'06 Rubicon
jkp is offline
post #3 of 10 Old 09-19-2014, 09:00 PM Thread Starter
coconut_pete
the 204 is smaller than the mounting surface
post #4 of 10 Old 09-19-2014, 09:59 PM
chris142
those filters are interchangeable. both are 3\4x16 threads and both use the same gasket,bypass etc. just one is short and fat and one is longer and skinny. if one wont screw on you may have gotten a dud.bad thread maybe.
chris142 is offline
post #5 of 10 Old 09-20-2014, 06:30 AM
jkp
204 is the correct one. Be sure the filter is a 204, sometimes they are in the wrong box.
Or it is damaged.
'92 Islander
'06 Rubicon
jkp is offline
post #6 of 10 Old 09-20-2014, 07:35 AM
RandyTJ
I always use the Motorcraft FL1 A or a Purolator L 30001.
Both are the larger size filters.
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Goodyear 315/75/16 MTR's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
1999 XJ 6.5 Lift, Rusty's Long Arm, Four Link Rear Suspension, ARB Lockers Front and Rear, Alloy Axles....
RandyTJ is offline
post #7 of 10 Old 09-20-2014, 09:00 AM
TJJP77
TJJP77's Avatar
Agreed - if the larger filter fits, why not? More filtration capacity (within reason) is generally a good thing.
I tend to use the PureONE filters, and I also like Baldwin, but they are a pain to find. The outer can on the Baldwin is so thick I'd swear you can hammer nails in with it.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #8 of 10 Old 09-20-2014, 09:29 AM
aparke4
aparke4's Avatar
M1-301 for the 4.0 iirc.
aparke4 is offline
post #9 of 10 Old 09-21-2014, 07:26 PM Thread Starter
coconut_pete
thanks for the input. it was the "long and skinny" vs the "short and fat" thing that had me worried.
post #10 of 10 Old 09-21-2014, 08:24 PM
jjvw
jjvw's Avatar
That's what I've been using. Although, I don't think I have a good argument for why I use the larger filter.
The one time I went to Grease Monkey, I was criticized for wasting my money by using the larger filter. That filter was 3k miles old, which they forced me to change because all filters filter the same.
2003 Rubicon
jjvw is offline
