Odometer and Trip Meter - JeepForum.com
 2Likes
  • 1 Post By Jonny Jeep
  • 1 Post By JeffBowser
post #1 of 12 Old 10-12-2021, 07:58 PM Thread Starter
JeepJeffW
JeepJeffW's Avatar
1997 4.0L TJ. Is there a way to set the trip meter so it comes up as the default (displays) instead of the odometer? Thanks
"The government cannot give to anybody anything that the government does not first take from somebody else. You cannot multiply wealth by dividing it."
~~~~ Dr. Adrian Rogers, 1984
JeepJeffW is offline
post #2 of 12 Old 10-14-2021, 07:06 AM
Jonny Jeep
Jonny Jeep's Avatar
The simple answer is no.
TheBoogieman likes this.
Jonny Jeep is offline
post #3 of 12 Old 10-14-2021, 08:40 AM
JeffBowser
JeffBowser's Avatar
The complicated answer is nope.
JeffBowser is offline
post #4 of 12 Old 10-14-2021, 06:43 PM
greenmachine99
greenmachine99's Avatar
If I’m reading this right, you want the trip meter to come up when the jeep is started instead of the odometer correct?
greenmachine99 is offline
post #5 of 12 Old 10-14-2021, 11:59 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
The simple and complicated answers are both correct.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #6 of 12 Old 10-16-2021, 03:53 AM
Jonny Jeep
Jonny Jeep's Avatar
Another complicated answer is that it could be made to happen.
It would require some electrickery though. At least one wire would have to be run to the cluster circuit board. A dual 555-timer circuit could be used to provide a short pulse to the cluster circuit board, which would make it think the button has been pressed shortly after the ignition switch is turned on.
post #7 of 12 Old 10-16-2021, 12:00 PM
greenmachine99
I’ve never modified my cluster but it starts on whatever was on whether it be odometer or trip meter, when the jeep was shut off last.
post #8 of 12 Old 10-16-2021, 01:59 PM
Jonny Jeep
Jonny Jeep's Avatar
Originally Posted by greenmachine99 View Post
Iíve never modified my cluster but it starts on whatever was on whether it be odometer or trip meter, when the jeep was shut off last.
I've never noticed that on mine, probably because I normally just have the odometer reading displayed. I'm going to have to try turning my ignition off when the trip meter is showing now. just to see if that happens on mine.
The FSM just states that the "last normally displayed distance" will be displayed.
post #9 of 12 Old 10-17-2021, 01:16 PM
RLD831
RLD831's Avatar
I've had a 2001, a 2006, and now a 2004, all of which behaved exactly like you're looking for. I wonder if that's just a 97 issue.
RLD831 is offline
post #10 of 12 Old 10-17-2021, 04:10 PM
Jonny Jeep
Jonny Jeep's Avatar
I've tried switching to trip meter and turning ignition off and back on with my 97 now.
Odometer display defaults to the total mileage display when ignition is turned on.
post #11 of 12 Old 10-19-2021, 06:35 AM
JeffBowser
JeffBowser's Avatar
This isn't default behavior on all years? I never knew. Man, I wish mine would stay where I left it.
post #12 of 12 Old 10-20-2021, 07:53 AM
greenmachine99
Apparently not. I just assumed all TJ’s stayed where you left it like my 99. Learn something everyday!
