Odd Driveability issue , please advise - JeepForum.com
post #1 of 4 Old 12-29-2012, 06:03 PM Thread Starter
lostone73
lostone73's Avatar
My TJ has been running awful lately, it struggles accelerating past 3000 RPM or anything over half throttle it "pops" through the throttle body.
What Ive done so far:
Checked fuel pressure , result was 44 psi at all speeds and loads
checked exhaust and CAT for restrictions, none found.
Also this problem is not tripping any DTC's at all.
I have a decent pro type scan tool, here are some results
TPS seems ok .70vdc closed and 3.83 or so at WOT
MAP, CMP and O2 readings seem ok and within range
WHAT I DID NOTICE WAS THIS:
Crank Position Sensor (CKP) readings were a little odd, at a smooth idle(650 RPM) the CKP counts hold steady around 170-180counts, then will drop to 14 or 17 momentarily.
Has anyone seen this anomoly in the CKP counts or this driveability issue?
Simple explanation of faith :
Think of it as a movie. The Torah is the first one, and the New Testament is the sequel. Then the Qu'ran comes out, and it retcons the last one like it never happened. There's still Jesus, but he's not the main character anymore, and the Messiah hasn't shown up yet.
Jews like the first movie but ignore the sequels, Christians think you need to watch the first two, but the third one doesn't count, Moslems think the third one was the best, and Mormons liked the second one so much they started writing fan-fiction that doesn't fit with ANY of the series canon.
(credit to unknown author)
lostone73 is offline
post #2 of 4 Old 12-29-2012, 09:15 PM
hndswthtshdws
I'd start with new plugs and wires. Then a compression test.
Could be a valve hanging open or loose clearance. Spark wires crossed. Blown head gasket. Dirty distributor cross sparking, except you don't have a distributor.
If you filter out everything that has bad spelling and grammar, you can believe 95% of what you read on the Internet.
hndswthtshdws is offline
post #3 of 4 Old 12-29-2012, 09:33 PM
Curly5759
Depending on the update speed of your scan tool, the CKP readings are most likely normal. The CKP will count up to 250 (IIRC) then reset to 0 and count up again. Rinse, repeat. What you are probably seeing is the scan tool refresh rate catching a reset in the act. Try graphing the CKP if your scan tool can do that.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #4 of 4 Old 12-29-2012, 09:47 PM
Patrick H
Patrick H's Avatar
CKP count is normal. Just watched a data stream on an XJ 4.0 the other day after a CKP sensor replacement.
'01 TJ
'48 CJ2A
Patrick H is offline
