OBA Help! Will this work? - JeepForum.com
post #1 of 5 Old 10-29-2008, 10:41 PM Thread Starter
2006LJRubicon
2006LJRubicon's Avatar
I saved this from our annual garage cleaning. Can i use this canister for my OBA? If so, what kind of regulator do i need to purchase. Thanks
2006 Black Unlimited Rubicon---RE 5.5 LA Tri Rear---JKS ACOSs frt and rear---Kilby Rocker Knockers---Rampage Bumpers with Rear Tire Carrier
2006LJRubicon is offline
post #2 of 5 Old 10-29-2008, 10:53 PM
HankyDanky
HankyDanky's Avatar
1989 XJ Cherokee
Are you talking about CO2 or using compressed air for it? Ex. Viair air pump or AC compressor.
You can use alot of things for an air canister.. keg shell, fire extinguisher, sealed bumper/rock slider. But it is important to know the PSI rating. For CO2 it looks pretty good.
http://ruggedrocksoffroad.com/ultima...it-p-3493.html - Just to give ya an idea.
1989 Cherokee 4.0l, Rubicon Express 4.5" XJ Super-Flex System, 33x12.50x15 KM2's
The XJ Rebuild-
People are always grabbing the handles, clutching the seat, or stomping an imaginary brake peddle when we're out having fun.
HankyDanky is offline
post #3 of 5 Old 10-30-2008, 12:58 AM Thread Starter
2006LJRubicon
Just to air up the tires. I grabbed this scuba diving tank before it met its maker. I want to have somethat will work but i dont want to have to spend an arm and leg.
post #4 of 5 Old 10-30-2008, 08:07 AM
CrawlinLJ
I used a scuba tank for a few years to air up my tires. From the looks of the picture the tank has a few years on it. If you keep the scuba valve on it , a scuba shop can fill it but it has to be in hydro and visually current. This can cost from $20 to $40 to have done...The tricky part is finding a scuba yoke with the fittings for a regulator to bring the pressure down to a safe range to fill tire or operate some tools. A welding shop I doubt will have a scuba yoke adapter to fill the tank and then you have to change to valve too. I believe the CO2 thread is diffenerent than the Scuba tank size. Just take the tank to a welding suppply and tell the guy what you want to do. He may have the valve that fits the top of the tank that all of the appropriate regulators can screw into and you will be good to go.
2006 Rubicon LJ, 4.0 liter, 4 speed automatic, 5.5" Rubicon Express, 37" x 12.5" Krawlers on Champion Beadlocks, Dynatrac Pro-Rock 60 axles/5.13 ratio w/ high steering kit, Dyna-Loc front hubs, J.E. Reel 1350 cv drivelines, Atlas 4 speed/5.38:1, Walker Evans Shocks, PSC Hydraulic Assist steering, Nth Degree Oil Pan and Transmission Skid, Premier Power Welder, Kilby On Board Air, Warn 9500si, Dual Optimas, Hansen Front Bumber, All J Products Rear Bumper & Boulder Bars, PIAA Driving Lights, Rock Lights, Ham Radio, CB, Garmin 76cs GPS,Wet-Okeole seat covers
CrawlinLJ is offline
post #5 of 5 Old 10-30-2008, 08:11 AM
jeeptp75
Guest
I 2nd that, I really think the hardest thing for you is going to be the threading on the scuba tank and fitting tha the threading of a regulator. As far as age and PSI, do you plan on filling it with an on board air compressor or filling it as needed from a garage air compressor, either way you will probubly only need about 200 psi if that regulated down to fill your tires or run air tools. The tank is probubly rated for much higher than that it just might be out of date. You could still have it retested just to be safe but I doubt you'll need to based on how much pressure your really going to be putting into it.
jeeptp75 is offline
How well does this work? ksjeep226 JK Wrangler Technical Forum 4 07-22-2010 02:24 PM
Electrical work done yesterday now today stranded at WORK! Dannyboy6292 YJ Wrangler Technical Forum 8 01-05-2010 08:07 PM
What Will Work!!!!!!!!!!!! Trikerkeith YJ Wrangler Technical Forum 6 10-24-2008 11:10 AM
HELP!!!! 4.0 head guys will this work? I tried a different one that didn't work!!! jeepdude1987 YJ Wrangler Technical Forum 5 10-11-2008 10:35 AM
Speedometer and Tac work and don't work drzima TJ Wrangler Technical Forum 2 08-16-2008 11:39 AM
