NV3550 Venting Oil? - JeepForum.com
post #1 of 4 Old 03-26-2019, 11:05 AM Thread Starter
TheFreedombird
NV3550 Venting Oil?
I recently swapped my AX15 out for a remanned NV3550. Been driving it for a couple of days now and kept smelling a little bit oil burning and chalked it up to be oil that had ended up on the exterior of something burning off during the swap. I came to that conclusion because I could see any new oil spots anywhere. Then today I was driving and suddenly had smoke coming through my floor pan. I am not familiar with NV3550's but the research I had done I was able to locate what I believe to be the vent. There aren't any blown gaskets and fluid appears to be coming out of nowhere. The highest wet spot is where the vent is. If I had overfilled it with trans oil is it possible the pressure inside could have forced some fluid out the vent?
A smart man learns from his own mistakes. A wise man learns from others mistakes
TheFreedombird is offline
post #2 of 4 Old 03-26-2019, 11:34 AM
dbbd1
dbbd1's Avatar
Where did you get the NV 3550 from?
Why did you swap out AX-15?
I'd like to swap one into my '06.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #3 of 4 Old 03-26-2019, 11:49 AM
2jhanna
Overfilling is easy to check and correct. Pull the fill plug, let excess run out, reinstall fill plug when no more runs out. Level ground, btw.
Do you have the vent tube in place and running up to the left radiator support.
Also, what fluid did you use, synchromesh compatible ??
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #4 of 4 Old 03-26-2019, 01:30 PM Thread Starter
TheFreedombird
2jhanna I did use synchromesh compatible and thank you for the advice. Now time to find a 17 mm hex.
dbb1 The swap was because my ax15 was out of a 92 Dakota from a scrap yard. It is the one from my auto to man conversion. At the time I didn't have the money for a new trans then a couple of weeks ago a bearing or two blew up and the gears ate it all up.
nv3550 , tj , vent
HELP! Massive oil leak 2.5 YJ Malenlie Engines & Drivetrain 2 03-16-2019 12:51 AM
Do I have another faulty PCM? rcroane TJ Wrangler Technical Forum 42 02-13-2019 12:08 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Added Sea Foam to engine oil 1st time 3hounds ZJ Grand Cherokee Forum 21 01-09-2019 10:06 PM
How to change the oil temperature and/or oil pressure switches/senders/sensors dudesqueak WK Grand Cherokee & XK Commander Forum 2 12-01-2018 01:49 PM
