NV3550 Shift Tower Bolt Size?? Also stripped :( Please Help! - JeepForum.com
post #1 of 7 Old 03-11-2013, 05:24 PM Thread Starter
ProWhistle
Im in a bit of a pickle here:
I changed the clutch about a month ago and removed the whole shift tower at the time by removing the 4 bolts (as compared to the other method). They were stripped so I went to the stealership and they wanted $17 for the 4 bolts :O So i decided to grind slots in the old bolts and use a flat head to screw them back on ;D
Anyways...Now the slots are too corroded to unscrew (for fluid change) and I made a noob mistake by already draining the fluid -.- I could use the fill plug but my main concern is getting these bolts off and replacing them.
So my questions are:
1. Does anyone know the bolt size for these? So I can pick some up from somewhere else, heres link to bolts im talking about (part 85).
http://nv3550.com/wp-content/uploads...k-and-Gear.jpg
2.Any ideas other than hammering a socket on em' to get these stripped bolts off? :P
I hope you wise jeepers out there can help me out!! I could use the fill plug but my main issue if getting these bolts off and replacing them
ProWhistle is offline
post #2 of 7 Old 03-11-2013, 08:35 PM Thread Starter
ProWhistle
Anyone have the slightest clue?
post #3 of 7 Old 01-09-2014, 08:50 PM
Ben8822
Did you find out?
Check out my on going build thread http://www.4btswaps.com/forum/showthread.php?35409-4BT-Swap-into-my-2000-Jeep-TJ
Ben8822 is offline
post #4 of 7 Old 01-09-2014, 08:59 PM
Karottop
Penetrating oil for a day or two. You can drill a hole thru the center of it, that usually breaks its back. You'll still need to get a bite on it afterwards tho. You can also try a reverse cut drill bit, sometimes you get lucky and it will back the bolt out while ur drilling it.
You'll still probably spend more then $17 on equipment taking these bolts out
Karottop is offline
post #5 of 7 Old 01-10-2014, 02:04 AM
NH-JK
It's also really tight in that space... Hmmm
NH-JK is offline
post #6 of 7 Old 01-12-2014, 12:50 AM
Ben8822
I need to know the bolt sizes because my trans doesn't have any... Anyone have a clue? or is there a kit of some sort?
Ben8822 is offline
post #7 of 7 Old 01-12-2014, 07:59 PM
J03_TJ
J03_TJ's Avatar
I looked in my parts manual and it shows p/n 4741 144, but no thread info. Searching "jeep bolt 4741144" in google I saw it for sale for under $2 each, but not at any site I've ever used. Sorry dude, I tried.
Can you take one out and take it to a hardware store and find a nut that fits it and then the matching bolt?
J03_TJ is offline
bolt , nv3550 , seized , shifter
