NV3550 clutch and shifting noise - JeepForum.com
 1Likes
post #1 of 17 Old 08-03-2021, 07:29 AM Thread Starter
Hoffertot
Hello all,
I'm having some interesting noises coming from the clutch/transmission, and was hoping to get an opinion on possible culprits before I pull the tranny.
When I push the clutch in, a whirling noise beings to appear after about 3-5 seconds. It sounds like a dry bearing, but unsure why it doesn't appear immediately when the clutch is pressed. I replaced the throw out bearing about 3 years ago, so I was thinking this was the leading suspect again.
What gets me is there is a second tier to this noise. With the clutch still pushed in, if I move the shifter into a gear, a very loud scraping noise then appears. This sounds much worse then a dry bearing, and more like metal scratching on metal. If I return the shifter to neutral(clutch still pressed in), the noise does NOT go away. The noise disappears when the clutch is released, or once a gear starts to engage.
Could all this noise be from the throw out bearing, or is something else at play here?
Thanks in advance!
Hoffertot is offline
post #2 of 17 Old 08-03-2021, 03:30 PM
bobjp
It is the pilot bearing. When stopped, in gear, and clutch pressed, the pilot bearing needles are spinning. When moving in gear with the clutch out, the pilot bearing needles are not spinning.
97 TJ sport.
bobjp is offline
post #3 of 17 Old 08-04-2021, 06:30 AM Thread Starter
Hoffertot
When stopped, in neutral, and clutch pressed, can the pilot bearing still be making noise too?
post #4 of 17 Old 08-04-2021, 06:45 AM
53flattie
53flattie's Avatar
1936 CJ2A
Anytime the engine is running, the crank is spinning. The pilot bearing is inside the crank - so the pilot bearing is always spinning, regardless of the position of the clutch.
Sent from my iPhone using Tapatalk
53flattie is offline
post #5 of 17 Old 08-04-2021, 04:18 PM
bobjp
The pilot bearing as a whole is always spinning if the engine is running, but it's not "working" unless there is relative motion between the flywheel and the input shaft of the transmission. The needles are not rotating about their axis.
There could be relative motion between the flywheel and shaft in that scenario. In the first post, you mentioned that scenario being quieter than when you put it in gear (while stationary, clutch pressed). That makes sense. When you put it in gear, you are stopping the input shaft of the transmission.
97 TJ sport.
bobjp is offline
post #6 of 17 Old 08-05-2021, 01:20 PM
53flattie
53flattie's Avatar
1936 CJ2A
In neutral, the input shaft of the transmission is stationary. But the pilot bushing is still rotating around it, causing the needle bearings to spin.
No? I’m just thinking out loud…
When you shift into gear, the input shaft is then spinning at the same speed as the pilot bearing, at which time they essentially become one unit.
TheBoogieman likes this.
post #7 of 17 Old 08-05-2021, 02:52 PM
bobjp
If the clutch is not pressed in neutral, then the input shaft is spinning at the same speed as the engine. If the clutch is pressed, then the input shaft could be spinning some, but not much.
When you shift into gear while stationary, the input shaft comes to a stop. It doesn't start spinning again until you begin to let out the clutch.
97 TJ sport.
bobjp is offline
post #8 of 17 Old 08-11-2021, 10:04 AM Thread Starter
Hoffertot
**Update**
I have pulled the tranny now, and it looks like a pilot bushing has been installed instead of a pilot bearing. All the noise symptoms I had seemed to lean towards the pilot bearing, so what else could potentially be causing all the noise? Could a worn bushing causing some grinding/binding else ware? I've attached some images of the bushing.
Disclamer, this is on an 87 yj that a previous owner did a NV3550 swap on it
post #9 of 17 Old 08-11-2021, 03:33 PM
bobjp
What do the condition of the bushing and the input shaft look like? Any gouges/scars? Do you have calipers to measure the ID?
Inspect your clutch disc. I had a cracked clutch disc that made a scratching rattling sound whenever I was at a stop with the trans in gear and the clutch pressed. The noise went away when the trans was taken out of gear.
97 TJ sport.
bobjp is offline
post #10 of 17 Old 08-12-2021, 06:37 AM Thread Starter
Hoffertot
The is a shallow gouge on the face of the bushing, you can kind of see it in the picture as a darker spot, but the ID of the bushing and the input shaft look and feel quite good. No concerning grooves, or wear marks. From what I can see, the clutch disc also looks good, no cracking that I can find. The clutch and pressure plate were also replaced a few years ago along with the first throw out bearing I did.
The flywheel and pressure plate surfaces also look real clean with no noticeable grooves or gouges. I do have calipers, but the bore of the bushing is too deep to get it in there. Going to grab something from work today to help measure.
I can't remember how much resistance there should be on the throw out bearing, but I can give it a good spin by hand, and it will keep spinning for a few seconds.
post #11 of 17 Old 08-12-2021, 06:38 AM
53flattie
53flattie's Avatar
1936 CJ2A
Just for comparison, this is what the pilot bearing looked like in my 3550.
post #12 of 17 Old 08-12-2021, 06:41 AM
53flattie
53flattie's Avatar
1936 CJ2A
And this is the bad one that came out of it.
Hard to tell from your pictures, but perhaps the roller bearing in the center of yours is gone like mine was…
post #13 of 17 Old 08-12-2021, 10:07 AM Thread Starter
Hoffertot
Oh man, that thing was toasted! I have yet to pull the bushing so it is possible only a thin outer race remains that I couldn't see from initial inspection.
Did you find metal shavings/roller bearings during the disassembly, or had it all worked its way out? Initial inspection I do not have any signs of metal shavings around this bushing to indicate the bearing deteriorated. I plan to pull the bushing tonight, so maybe I'll learn more.
Thanks for the pictures.
post #14 of 17 Old 08-12-2021, 05:13 PM
bobjp
You have the bushing type pilot while 53 has the roller bearing pilot. You're not missing any parts.
The scenario you described in your first post: Noise while stopped, in gear, clutch pressed eliminates the transmission as the culprit. And going between in gear and out of gear in the same scenario isn't going to make a difference to the TOB.
So there's something off about the pilot bushing, the clutch disc, or pressure plate.
97 TJ sport.
bobjp is offline
post #15 of 17 Old 08-16-2021, 10:05 AM Thread Starter
Hoffertot
To this point everything has been pulled.
Confirmation of just a pilot bushing. ID measures 0.77, transmission shaft measures 0.75. No signs of wear marks at all on shaft. Is this gap acceptable?
A lot of inspection on clutch disk, no signs of cracking, scratches, pitting, etc.
Pressure plate also looks good, just shinny metal on end of the fingers where the throw out bearing meets. Looks like normal wear here.
Clutch fork, pivot ball, retaining clip all were in place and look good
Throw out bearing spins freely, no binding/grinding, but of course unloaded. Throw out springs to fork are a little loose.
I'll need to get a picture, but the only oddity I see is in the very end of the main bearing retainer. The tip of the snout end looks ground down to a very thin sharp point. Almost as if maybe it was in contact with something, pressure plate fingers maybe? Could the pressure plate fingers when compressed make contact with the main bearing retainer snout? I have only driven maybe 5k miles since all the clutch component were replaced, but I would think if that was the case, the noise would have been present immediately, and not related to shifting into gear.
Maybe I'm off base here, but any other suggestions? I can get some more pictures if that would be helpful.
Thanks.
