notchy to mild grinding when shifting. - JeepForum.com
post #1 of 3 Old 09-25-2008, 08:37 PM Thread Starter
NC4stroker
2014 WK
I have an 04 rubi with a 5-speed. The tranny was replaced at 60k under warranty (currently has 65K miles), and a new clutch was installed then too.
I recently replaced the transmission fluid with Redline MTL and have noticed 1st to 2nd will grind at times, and 2nd to 3rd mildly grinds almost every time.
This occurs with the trans. cold and at operating temp.
I have only had the jeep a couple of months, but I don't remember the jeep shifting like this prior to changing to MTL.
Anyone using Redline MTL?? Thanks all.
NC4stroker is offline
post #2 of 3 Old 09-25-2008, 08:39 PM
Jeeper4ever
I use that in mine and have not had this issue, is it only when it is cold? How long ago was the trans replaced?
2004 Silver TJ Sport 5 Speed Manual Dual Tops
3" BDS Lift 33x10.50 BFG M/T
Warn Rocker Guards, Keystone Fab Rear Bumper & Tire Carrier w/ 48" Hi Lift
Silverstar Headlights, Hella 500 Driving Lights
Jeeper4ever is offline
post #3 of 3 Old 09-25-2008, 09:10 PM
Sarge37
Guest
Recommend you check the trans fluid. It may be low or the rear seal may be leaking. This will cause hard shifting in a manual transmission. You dont have a dipstick, you will have to pull the plug on the side of the xmsn and check. If the fluid is at the filler hole, then you are good to go, if not then service till it is. While your underneath, check for leaks or sprayed oil. If its there then you probably have a bad rear seal.
Let us know what you find out.
Good luck
Sarge37 is offline
Grinding when shifting down into second TJted33 TJ Wrangler Technical Forum 13 07-06-2010 02:24 PM
Grinding when shifting to second 02BlackSahara TJ Wrangler Technical Forum 8 04-14-2009 12:25 PM
Grinding when shifting YJyoungster YJ Wrangler Technical Forum 10 01-02-2009 11:22 PM
Grinding shifting to second pokernaked YJ Wrangler Technical Forum 42 11-17-2007 08:55 PM
2004 SE 5speed NOTCHY SHIFTING! my911cab TJ Wrangler Technical Forum 4 01-03-2005 08:44 PM
