Not your typical blinker problem - JeepForum.com
post #1 of 18 Old 10-23-2010, 06:46 PM Thread Starter
freeskier93
I hate Jeep blinkers. A couple months a go I replaced my blinker switch because the auto cancel was broken (still doesn't auto cancel when turning left, only right) and the left signal would turn on with brake. Replacing the switch solved the problems, except for the one.
Anyway, not to long ago I started having erratic blinker problems. It only happens to the left blinker. What happens is when I turn it on it will blink fast, like it does when the brake lights aren't working, but it only happens in the mornings. It will blink fast, sometimes it will even fluctuate in speed.
I don't think it's the bulb, and the only other thing I could think of was moisture in the mornings.
Any other ideas?
P.S. while I'm at it, anyone have some ideas on why the auto cancel doesn't work when turning left? I had done some searching about it at one point but didn't turn up much.
freeskier93 is offline
post #2 of 18 Old 10-23-2010, 06:59 PM
scottbr
scottbr's Avatar
2016 JK Wrangler
Sometimes my left blinker goes on when I hit the brakes. I think it's a wiring problem, there might be a friction point inside the harness that wears to the point that it does that. If it's not in the connector to the taillight or turn light, I'd say drop it, you'll go crazy chasing it.
My cancel cam doesn't work when I turn right. It's somehow gotten off-center, I think you have to take the column apart to get to it.
scottbr is offline
post #3 of 18 Old 10-23-2010, 07:01 PM
mukluk
mukluk's Avatar
I'd bet you have corrosion on the bulb contacts and/or grounds for your light assemblies. Try pulling the bulbs, cleaning the sockets and cleaning up the grounds.
For the auto cancel your best bet is to pull the switch again and inspect for broken parts or possibly the little return springs popped off.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 18 Old 10-23-2010, 07:03 PM Thread Starter
freeskier93
Should probably check to see if the light is even working or it's just in the dash.
Ugh, tearing into the steering wheel sounds fun. If I turn the steering wheel left all the way, then it will cancel, so that sounds right. What ever mechanism in the steering column isn't working on the left side, and when the wheel turns 360 the right side mechanism catches it.
Thanks for the info.
post #5 of 18 Old 10-23-2010, 07:06 PM Thread Starter
freeskier93
I'll check all the bulbs. Might be a good excuse to switch to LED bulbs. I replaced switched all the interior lights to LEDs and am very happy with it.
I know for sure it isn't the switch. When I replaced it, the cancel mechanism in the switch worked perfectly and has never canceled left the second I put it in.
edit: When I say the switched worked perfectly, before I installed it I checked the mechanism.
post #6 of 18 Old 10-23-2010, 08:27 PM
VT_Jeeper
I'm not sure if this will help your problem but.....I just fixed a similar problem yesterday thanks to the guys on this forum. Out of the blue I started having blinker problems, right blinker blinking fast, dim tail..brake and reverse lights on the passenger rear. I thought it was the trailer wiring harness. I finally got that unplugged and they were still messed up. Anyway..I read a post on here of a guy having the similar problems...it was suggested to him to check the three bolts that hold the rear lights to the body have like a "rubber" washer on them.
I thought to myself...way to easy of a fix. I went and took the bolts out and sure enough there was a clear rubber washer on the bolts. I took all of them off and presto...everything works fine..they just weren't getting the right grounding contact that they needed..I guess.
Hope this might help!
'06 sport, 4"RC, 33" BFG m/t's, Warn, LoD, AtoZ, lights, skids and other goodies...
VT_Jeeper is offline
post #7 of 18 Old 10-23-2010, 08:30 PM Thread Starter
freeskier93
Hmm, I'll have to look into this. I've been taking my tail lights off a LOT because I'm repainting the Jeep, so maybe something got messed up.
post #8 of 18 Old 10-23-2010, 09:31 PM
MikeyJ
Sounds like a bad ground somewhere or your clockspring in your steering wheel is bad.
MikeyJ is offline
post #9 of 18 Old 10-24-2010, 07:46 AM
er2ergrn
Been having the same problem with erratic blinker on left side. What I found was the socket was corroded and bad contacts. The socket can be disconnected from the wiring harness and I am going to order a new one in morning. I am sure this is probably a stealership only item.
Unless someone happens to know about somewhere else?
er2ergrn is offline
post #10 of 18 Old 10-24-2010, 11:06 AM
Tjosh97
I have the same problem on my 97 and still have not fixed it, what can you use to clean out the sockets? Terminal cleaner or something to eat any corrosion?
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline
post #11 of 18 Old 10-24-2010, 11:08 AM
Tjosh97
Can you post a pic?
Tjosh97 is offline
post #12 of 18 Old 10-24-2010, 12:12 PM
er2ergrn
Originally Posted by Tjosh97 View Post
Can you post a pic?
We already put everything back together, next time I will take pics. We cleaned it with WD-40 and cleaned the contacts with a q-tip and put it back together and wiggled the bulb until it blinked correctly and then reinstalled it and it is working right now but I am sure I will need to get a replacement soon.
Oh, be very careful when cleaning the brass contacts. I put very little pressure on them and they bent over very easy!
er2ergrn is offline
post #13 of 18 Old 10-24-2010, 12:51 PM
Tjosh97
Thx, Im gona try to go thru and clean thoroughly to make sure this wont fix my prob too.
Tjosh97 is offline
post #14 of 18 Old 10-24-2010, 12:54 PM
Chiles
Chiles's Avatar
Hand signals.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Chiles is offline
post #15 of 18 Old 10-24-2010, 01:03 PM
hefightsfire
hefightsfire's Avatar
Alcohol preps work well. May have to work them in on the tip of something but they will clean it up nicely.
hefightsfire is offline
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 05:34 AM
Tranny issue, NOT typical syncro problem... USMC_JeepGuy YJ Wrangler Technical Forum 0 09-10-2009 09:48 PM
vacuum acutator are they a typical problem c-wag YJ Wrangler Technical Forum 3 06-03-2009 04:30 AM
Not your typical rear storage problem superdave624 TJ Wrangler Technical Forum 1 09-08-2008 02:26 AM
gauges stopped working but doesn't seem to be the typical problem newvances TJ Wrangler Technical Forum 3 04-28-2007 06:59 AM
