Not sure whats wrong but I hear a sound when I turn sounds like I'm snapping my axle - JeepForum.com
post #1 of 33 Old 12-09-2009, 08:59 PM Thread Starter
97tjfinatic
please help me figure this out i know i was retarded wit my jeep but i was peeling out alot wit my friends and my last one sounded like i snapped my axel but when i shifted in to first nothing was wrong although when i was driving away i made a turn and it sounded like a really loud metal snap but it only does it speratically not constant and my back right lift up a little when it happens
I LIVE, I RIDE, I AM.....JEEP
97tjfinatic is offline
post #2 of 33 Old 12-09-2009, 09:01 PM
Imped
Imped's Avatar
Another good reason not to do burnouts with jeeps and to use grammar so others can understand what you're saying.
OlllllllO
IndyORV
Imped is offline
post #3 of 33 Old 12-09-2009, 09:01 PM
never monday
do you have a locker back there? sounds like a Detroit or a lunchbox acting noramlly.
never monday is offline
post #4 of 33 Old 12-09-2009, 09:09 PM
red rubi
So long pal!
red rubi's Avatar
Peeling out your Jeep
Fill out your profile; axle, tires, tranny etc. Hopefully you only effed up your axle shaft. Could be ring& pinion but we might be able point you in the right direction with more info. welcome
red rubi is offline
post #5 of 33 Old 12-09-2009, 09:12 PM Thread Starter
97tjfinatic
i dont know i bought the thing used last thursday and i have no specifics on the thing all i know is its a 97 tj 4.0 straight six 5 speed manual has 31x10.5 tires and used to drive like a dream until this happened and before my throttle sensor went
post #6 of 33 Old 12-09-2009, 09:13 PM Thread Starter
97tjfinatic
thanks red ruby
post #7 of 33 Old 12-09-2009, 09:13 PM
2006_Sport
2006_Sport's Avatar
Why does it say in your profile that you have 33s then? Profiles gotta be accurate for us to help you.
You probably damaged the rear end because you wanted to be cool and burn out.
2006_Sport is offline
post #8 of 33 Old 12-09-2009, 09:19 PM
boarder15675
It sounds like a broken pinion/ring gear tooth. I had the same problem a couple months ago. I noticed when one time I was stopped, started going, the whole jeep torqued to one side, a big snap, then I started moving. That was the pinion tooth gouging into my dif cover. If you are even the slightest bit mechanically savvy you can check that yourself, so you don't have the shop wasting your time and money 'finding' the problem.
boarder15675 is offline
post #9 of 33 Old 12-09-2009, 09:21 PM Thread Starter
97tjfinatic
i'll check it myself tomorrow thank you boarder
post #10 of 33 Old 12-09-2009, 09:24 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Like the above never monday said, it sounds like a Detroit or a lunchbox behaving normally! He just needs to do a little investigative work maybe?It's new to him.
GOLENJEEPTJ is offline
post #11 of 33 Old 12-09-2009, 09:25 PM
MisterO
MisterO's Avatar
yup sounds just like when i broke my spider gears.. doesn't make a constant popping always, rather just happens when some of the broken teeth got caught between the R&P or rest of the spider gears.....
MisterO is offline
post #12 of 33 Old 12-09-2009, 09:26 PM
GOLENJEEPTJ
If it was a broken ring and pinion he wouldn't be driving the thing!
post #13 of 33 Old 12-09-2009, 09:27 PM
MisterO
MisterO's Avatar
could be the spiders.. and yes you can drive but it may explode..
MisterO is offline
post #14 of 33 Old 12-09-2009, 09:29 PM
fishinjeeper
fishinjeeper's Avatar
my rear detroit does this every now and then but there is no damage at all...like once a month. if you didnt buy it new then you might have some sort of locker in the rear. if there is no locker i would suggest you probably broke a tooth most likely on your ring gear. depending on where the chip lands it can make its way into the spider gears every now and then and tear your spider gears up too
Find God, your gonna need him.
Captain of the Little Liberator.
fishinjeeper is offline
post #15 of 33 Old 12-09-2009, 09:31 PM
red rubi
So long pal!
red rubi's Avatar
I like that theory but I don't think He'll be so lucky.
I think now would be a good time to change your diff fluid. Drain it into a clean plastic bucket either use a mesh strainer from the kitchen or take one of those magnet on a stick things and see what you find. Let us know.
red rubi is offline
whats is the sound i hear Brown6041 YJ Wrangler Technical Forum 1 05-07-2009 01:45 PM
Heater settings acting all wierd and hear clunk sounds when driving Vladimer TJ Wrangler Technical Forum 1 09-12-2008 08:06 AM
Whats your sound system, and how well can you hear it? Mymmars YJ Wrangler Technical Forum 46 09-11-2008 03:29 AM
Loud Snapping sound jake7893 TJ Wrangler Technical Forum 5 04-08-2007 07:48 AM
tire size snapping axle ??? wrnglrguy TJ Wrangler Technical Forum 14 10-08-2006 06:19 PM
