no power to blower motor - JeepForum.com
post #1 of 7 Old 09-14-2021, 07:59 PM Thread Starter
Steelhed3
Thank you for the help in locating the blower motor relay. Have changed heater selector switch, resister, blower motor relay. Removed old blower motor tested good but looked bad, very dirty. Did not reinstall old blower motor waiting on mail for a new motor. Made all the other connections and no power. Could not find power to any of the connections with engine running. Old school says likely a bad ground. Where could that be? Stumped. regg
Steelhed3 is offline
post #2 of 7 Old 09-14-2021, 08:29 PM
jtec
jtec's Avatar
2014 JK Wrangler
model, year, AC or no AC.
jtec is offline
post #3 of 7 Old 09-14-2021, 09:20 PM Thread Starter
Steelhed3
New to forum. My jeep is a 2001 TJ sport with A/C. Hope this helps with the no power to heater issue.
post #4 of 7 Old 09-14-2021, 09:22 PM Thread Starter
Steelhed3
2001 jeep tj with a/c.
post #5 of 7 Old 09-14-2021, 09:52 PM Thread Starter
Steelhed3
2001 jeep tj 4.2 auto a/c
post #6 of 7 Old 09-15-2021, 10:58 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
The place to start is to check for both 12v power & ground at the blower motor connector.
With the key on & the mode switch turned to any position except off check the dark green wire for 12v & the black/tan wire for ground. That will tell you where to go next.
Rubi4MyMrs is offline
post #7 of 7 Old Yesterday, 04:58 AM
aissa123
Deviations of power supply parameters from the norm can be for several reasons: transients, interruptions, voltage dips, voltage dips, voltage surges / overvoltages, voltage waveform distortions, voltage fluctuations, frequency variations. Check all these parameters
aissa123 is offline
