No Other Forum Has Been Able to Help Me... - Page 2 - JeepForum.com
post #16 of 37 Old 02-18-2010, 01:31 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Originally Posted by HawkSurf View Post
Ha. I'll accept fault on that one.
(JK) and that's not an 07-10' Jeep wrangler.
TheBoogieman is offline
post #17 of 37 Old 02-18-2010, 01:32 PM Thread Starter
HawkSurf
Originally Posted by 05jeeper View Post
I think I would try to isolate if its compressor or electrical first. I think the easiest way to do this is to pull the belt and see if it goes away.
Pull the belt? What would that do exactly?
HawkSurf is offline
post #18 of 37 Old 02-18-2010, 01:34 PM
jeepinmichguy_
jeepinmichguy_'s Avatar
i bet its the compressor. just a hunch though. i dont see the electronics causing a shake.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #19 of 37 Old 02-18-2010, 01:37 PM
Zen
If the problem is the compressor siezing up, the problem will go away when he removes the belt because the compressor will not put any strain on the engine.
Dont run the engine for too long like this or it will overheat. This should be a quick test.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #20 of 37 Old 02-18-2010, 01:39 PM
mdm
Farm Wheeler
Call it a car all you want. Some thin skinned people just like to get their panties in a wad because they can't accept the fact that their Jeep is a "car" just like some bike riders can't accept the fact that a Harley is a "motorcycle".
I really doubt it's electrical. The only electrical aspect of this is when the switch activates the clutch which makes the compressor spin. Check the compressor and its bracket.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #21 of 37 Old 02-18-2010, 01:39 PM
TJorDie
By chance was this Jeep a salvage title?
'03 Rubicon. Inca Gold. Auto, Full Doors / OEM Hard & Soft Tops, All stock..... Hot Wife Mod
TJorDie is offline
post #22 of 37 Old 02-18-2010, 01:40 PM
TheBoogieman
What about if he rides really fat girls around when the A/C is cut on? Violent shake.
post #23 of 37 Old 02-18-2010, 01:41 PM Thread Starter
HawkSurf
Nope. Bought her new.
HawkSurf is offline
post #24 of 37 Old 02-18-2010, 01:41 PM
pielet97
$20 bucks on the compressor, who ever you asked in your town, don't ever ask them for auto advice again.
I require things to do.
pielet97 is offline
post #25 of 37 Old 02-18-2010, 01:42 PM Thread Starter
HawkSurf
$20 on the compressor? Is that a repair estimate?
HawkSurf is offline
post #26 of 37 Old 02-18-2010, 01:42 PM
jeepinmichguy_
ΜΟΛΩΝ ΛΑΒΕ
post #27 of 37 Old 02-18-2010, 01:50 PM
jgorm
jgorm's Avatar
haha you wish! My friend was quoted $1200 for the AC on his van. They said that compressors don't usually freeze up unless there is a blockage in the system. then you need all the ac crap redone. There are 2 basic things that i would expect to cause this.
1. A compressor that is on its way out and "freezing" up a little to put excessive load on the engine. If you pull the belt off and run it for a few seconds you will know if that is the cause.
2. A bad or dirty IAC valve. If its old or sticky, or full of crap it won't work properly to add more air to compensate for the higher load with the ac on.
A long shot would be that you have bad 02 sensors, or a vacuum leak causing the AFR to be outside of the normal range and not run as well. But then it wouldn't run perfect with the ac off.
jgorm is offline
post #28 of 37 Old 02-18-2010, 01:53 PM Thread Starter
HawkSurf
Darn......
HawkSurf is offline
post #29 of 37 Old 02-18-2010, 01:55 PM
BWFBezerk
BWFBezerk's Avatar
Why would it overheat? Our 2.4 water pumps are timing belt driven thank you very much
You can pull the belt and drive around til the battery dies.
BWFBezerk is offline
post #30 of 37 Old 02-18-2010, 01:58 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Darn......
is it still under warranty? take it to Jeep and have them figure it out. even estimates should be free for most shops...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
a/c , acceleration , rumbling , shaking
Goodbye YJ forum Hello TJ Forum! figbush1 TJ Wrangler Technical Forum 11 12-26-2010 11:55 PM
new to the forum and have some?'s rmjuice9 YJ Wrangler Technical Forum 5 05-15-2009 07:51 AM
Thank you to this forum bobles YJ Wrangler Technical Forum 4 09-05-2008 05:33 AM
Goodbye YJ Forum Hello TJ Forum ;) figbush1 YJ Wrangler Technical Forum 0 10-18-2006 02:06 AM
New to this forum guyane YJ Wrangler Technical Forum 6 10-04-2004 01:42 PM
