No Lift with 35s - Page 8 - JeepForum.com
 1Likes
post #106 of 122 Old 03-31-2011, 10:38 PM
Deacon
Deacon's Avatar
Ah that's right. Good lord that's low.
Deacon is offline
post #107 of 122 Old 03-31-2011, 10:46 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by mynickburns View Post
Yes, no lift. All I have is my stock Rubicon springs. The only thing after market is adjustable control arms on the suspension.
what shocks do you have on there? are they stock length?
Mail crawling.
MisfitSeven is offline
post #108 of 122 Old 03-31-2011, 10:48 PM
justanotherjpr
justanotherjpr's Avatar
The OP's Jeep looks great.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #109 of 122 Old 03-31-2011, 10:51 PM Thread Starter
mynickburns
mynickburns's Avatar
The shocks are 1.5 inches longer than stock. The springs fall a little short at full droop.
mynickburns is offline
post #110 of 122 Old 03-31-2011, 10:53 PM
Moto4x4
I think your thinking about the track bar. That's why I'm not lifting this jeep. I hated the constant adjusting of everything to center the axles and pinion angles on my last jeep.
Oh but a lift can be so simple. BDS 2" Spring lift and shocks for 420 out the door for me. Literally all it is. Put the springs in, put the shocks on, and your good, thats IT. I have it and its great. Improved flex by a ton, and the ride is even nicer than stock. Better flex, better ride, better overall, no adjustments, you might wana look into it. No control arm stuff, no track bar stuff, nothing; its great!
By the way, sweeeet jeep. I like it a lot, like the color and everything
Moto4x4 is offline
post #111 of 122 Old 03-31-2011, 10:55 PM Thread Starter
mynickburns
Originally Posted by hustler905 View Post
Interesting. I just ordered some Prothane ghetto-bumps for just that reason.
Thanks for the feedback, it's tough sometimes to know if you're REALLY bottomed out when it's flexed like that.
My thoughts exactly! The pics are deceiving. What brand of stops did you get and how much where they?
post #112 of 122 Old 03-31-2011, 11:08 PM Thread Starter
mynickburns
Thanks for the suggestion, but you might want to take a closer look at your axles. I garauntee they are not centered under the jeep anymore. Better yet, have someone drive behind you down the road and they will see how sideways you jeep is. Not trying to be rude, but trust me, once your tires start wearing funny you will realize it. I know that 2 inches isn't much, but for me a TT is the next purchase.
post #113 of 122 Old 03-31-2011, 11:13 PM
hustler905
hustler905's Avatar
Prothane inserts that will get somehow attached to the lower spring perch, I think they were $45, worked to about $55 with shipping and stuff. I understand they mostly compress and should give me a softer end to the travel, and if they don't work as advertised, I haven't spent a lot.
hustler905 is offline
post #114 of 122 Old 03-31-2011, 11:18 PM
Moto4x4
Yea but its so miniscule its hard to even measure and you cant see it. My jeep doesnt lean when im driving and my tires are fine, your so skeptical
If i was to redrill a hole for the track bar it would be right next to the current one
Moto4x4 is offline
post #115 of 122 Old 03-31-2011, 11:21 PM
Deacon
Deacon's Avatar
It didn't even come with a rear trackbar relocation bracket? JUST springs and shocks?
It's not that hard to measure.
Deacon is offline
post #116 of 122 Old 04-01-2011, 01:13 AM
gebirgziege
Originally Posted by destr0 View Post
still look tougher than stock.
practicality over trendability.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #117 of 122 Old 04-01-2011, 05:06 PM
hustler905
hustler905's Avatar
I need to trim a little more from the front of mine. This is with a 1" BL and the factory bumps about half compressed.
Did the AEV front wheelwell cut remove very little material in the real world?
post #118 of 122 Old 04-01-2011, 09:16 PM
Moto4x4
Its only 2" of lift, i can get a picture of how centered it is on the jeep if you want haha
Moto4x4 is offline
post #119 of 122 Old 04-01-2011, 09:21 PM
Max713
Max713's Avatar
1997 XJ Cherokee
Fantastic.
Really, a fantastic job, something I would completely replicate if I had a TJ.
Max713 is offline
post #120 of 122 Old 04-01-2011, 11:07 PM Thread Starter
mynickburns
What can I say... I'm a perfectionist! Little stuff like that bugs me. If it doesn't bother you thats fine with me though. Let me know how your tire life goes!
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 10:11 AM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 09:13 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 07:32 PM
