No Lift with 35s - JeepForum.com
 1Likes
post #1 of 122 Old 03-20-2011, 07:39 AM Thread Starter
mynickburns
mynickburns's Avatar
No Lift with 35s
I've been debating in my head whether or not to post my Rubicon LCG build due to all the no lift critics on this forum, but I haven't really seen many highlined jeeps on the factory suspension with 35's. I have found an overline jeep, AEV jeep, and a lot of DIY highline with factory fenders, but not any tube fender highline with "no lift." So I figured I would put up some pictures of my Rubicon thus far in my build to help out others who might be trying to do the same as I did. I ended up going with TNT Hyline fenders in the front with the standard tube fender in the rear. The Hyline rear fenders they make were a bit too much for what I wanted. (I didn't want to stretch the rear suspension) I did have to cut the rear tube fenders in order to make sure I have enough room for the 35's though. Keep in mind I am on a budget so not everything is perfect, but I think it looks pretty good for just rattle canning the fenders. Anyway, here are some pics. I have a lot more pictures if anybody wants to see better detail of what I had to do on the front and rear fenders.
Also, I am putting the 35's on this Monday, so I will have the pics sometime next week with them on.
mynickburns is offline
post #2 of 122 Old 03-20-2011, 07:44 AM Thread Starter
mynickburns
Here are some more pictures that I couldn't fit in the first post.
post #3 of 122 Old 03-20-2011, 07:52 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Looks good. Are they going to fit?
TheBoogieman is offline
post #4 of 122 Old 03-20-2011, 07:58 AM
bigjermLJ
Cant wait to see 35's on it. I have 3" of lift total with 35's and metalcloaks but i have debated dropping the 2" suspension lift. Not sure with the LJ long belly the 2" might come in handy 1 day.
06 LJ
02 F350
bigjermLJ is offline
post #5 of 122 Old 03-20-2011, 08:12 AM
yarmish
yarmish's Avatar
Looks good..What did you use for a measurement when cutting your hood? Is that the stock washer bottle?
In a ZUK now....
yarmish is offline
post #6 of 122 Old 03-20-2011, 09:42 AM Thread Starter
mynickburns
From all the research I have done the front tires should fit fine. For the rear I used the template from AEV's website as a rough idea of what I needed to cut. Here are some pictures of the rear after I trimmed the corners and my tub. I centered a tire to get an idea of how much room I would have. I know stock rear suspension has about 3 inches of up travel so if its too close I have some bump stop extensions or I just won't disconnect the rear sway bar offroad.
post #7 of 122 Old 03-20-2011, 09:50 AM Thread Starter
mynickburns
I just measured about 3.25 inches along the side of the hood. That seemed to be how much it needed. I cut a little less at first to make sure and it turned out 3.25 was the magic number! But, I highly recommend you should still test fit and measure first!
post #8 of 122 Old 03-20-2011, 09:52 AM Thread Starter
mynickburns
As for the washer bottle, its a CJ bottle with pump I found on ebay for $20! It works great!
CWBreeding likes this.
post #9 of 122 Old 03-20-2011, 09:56 AM
biffgnar
biffgnar's Avatar
Rear swaybar should always stay connected
biffgnar is offline
post #10 of 122 Old 03-20-2011, 10:04 AM Thread Starter
mynickburns
I think your thinking about the track bar. That's why I'm not lifting this jeep. I hated the constant adjusting of everything to center the axles and pinion angles on my last jeep.
post #11 of 122 Old 03-20-2011, 10:05 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
don't forget to check the tire clearance at full bump & full flex. might need bumpstop extensions....
No he's not. he's talking about the rear sway bar. there is no reason to disconnect it...it provides stability you'll need off-road.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 122 Old 03-20-2011, 10:07 AM
biffgnar
biffgnar's Avatar
Nope. I know the difference between trackbars and swaybars. There is no reason to disconnect rear swaybar. And in fact even up front while disconnected may be better than stock, a connected offroad swaybar (e.g. Anti-rock) is better than disconnected.
biffgnar is offline
post #13 of 122 Old 03-20-2011, 10:14 AM Thread Starter
mynickburns
Cool, thanks. I will keep that in mind for my future upgrades.
post #14 of 122 Old 03-20-2011, 10:20 AM
lumpster
lumpster's Avatar
I see no problem with your jeep. I would see the problem if i did it to my jeep because i almost did. Even with 4 inches of lift and 35's with 1.25 inch BL my jeep drags on a regular basis. Its mostly due to the LJ having a worse break over angle, but its worth it to me.
As long as your jeep does what you want it to do its perfect. Thats all you ask for in YOUR jeep. Im glad you posted your "build" instead of hiding it. There are people that leave thier jeeps stock because they perform to the owners standards as is, I know its a hell of a lot cheaper to have this veiwpoint. Keep jeepin man, I want to see it with the tires on it, and yes, keep the rear swaybar connected, mine flexes really good in the back and the swaybar isnt my limit. The front swaybar on the other hand got replaced with an antirock, you can just disconnect yours. check your bumpstops and keep an eye on the front track bar, it tends to work loose at the axle end. You may want to upgrade to currie steering just to keep those 35's in line better.
lumpster is offline
post #15 of 122 Old 03-20-2011, 10:21 AM
Ef4life
I definatly like the no lift and 35s. It's what I have right now. Mine tends to rub in the rear a bit without bumpstop extensions, I think to ideally run the 35s tho it needs to be lifted about 2" to give more clearance
Ef4life is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 10:11 AM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 09:13 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 07:32 PM
