New Spark Plugs - JeepForum.com
post #1 of 11 Old 10-31-2016, 03:25 PM Thread Starter
RandyTJ
New Spark Plugs
Just hitting 50,000 miles on my LJ, still has original spark plugs and heading on a little trip to Tenn.
Thought it was about time to stick in some new plugs........went with Champion 7034 Double Platinum.
Have also read good things about Autolite App985, but the local parts store was out of them.
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Goodyear 315/75/16 MTR's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
1999 XJ 6.5 Lift, Rusty's Long Arm, Four Link Rear Suspension, ARB Lockers Front and Rear, Alloy Axles....
RandyTJ is offline
post #2 of 11 Old 10-31-2016, 03:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Great choice, that plug should perform well for 100k miles. The other great choice not mentioned is the Autolite XP-985 which is iridium tipped that is good for more like 200k miles.
Jerry Bransford is offline
post #3 of 11 Old 10-31-2016, 05:45 PM
joe_jeep
I did the xp985s in my lj.
They work well.
But i had 117k on the factory plugs.
They still worked good.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #4 of 11 Old 10-31-2016, 10:34 PM
Sudcalifornio
Sudcalifornio's Avatar
Is it true the inline 6 works better with cooper than platinum sparkplugs? should I believe?
[B]sudcalifornio[B]instagramand twitter
chapulinon snapchat
Sudcalifornio is offline
post #5 of 11 Old 10-31-2016, 11:50 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
No... IMO
Knuckelhead is offline
post #6 of 11 Old 11-01-2016, 12:09 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Originally Posted by sudcalifornio View Post
is it true the inline 6 works better with cooper than platinum sparkplugs? Should i believe?
NO x 2.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #7 of 11 Old 11-01-2016, 12:38 AM
Jerry Bransford
Administrator
No. While some ill-informed types believe that, it's not true at all.
Platinum and iridium plugs still have the solid copper core connection between the top connector and center electrode at the bottom. The electrodes are just coated with thin layers of platinum or iridium to resist erosion which allows them to last significantly longer. Like wearing shoes instead of going barefoot. Even conventional plugs usually have nickel plating on the electrodes, it just doesn't last as long.
post #8 of 11 Old 11-01-2016, 01:00 PM
joe_jeep
no!
really most correct plug numbers would work.
most of us are looking at how long they will last.
i doubt i will ever have to change plugs again on my lj.
glfwda #6624
joe_jeep is offline
post #9 of 11 Old 11-01-2016, 01:47 PM
1longcj
They sure like to preach the copper plugs for the 4.7 on the WJ side of this site.
1longcj is offline
post #10 of 11 Old 11-01-2016, 01:53 PM
Jerry Bransford
Administrator
The reason isn't stupidity, it is simple ignorance of plug technology and how to match it to the type of ignition system being used.
For example, single-tipped platinum plugs don't work well with distributorless 4.0L engines but they work perfectly well with the coil-on-plug design of the 4.7L V8 engine used in some Grand Cherokees.
post #11 of 11 Old 11-01-2016, 07:40 PM
btn
btn's Avatar
An interesting note of how the distributorless TJ 4.0s work: There are three coils, one for two plugs. Each coil fires both plugs at the same time, whether the piston is on the power stroke or the exhaust stroke for that particular cylinder. The spark current always flows through one plug and in through the second plug. One plug always has the current firing from the side electrode to the center elecrode, while its paired plug has the current flowing from the center elecrode to the side elecrode. That's why both electrodes have to match in whether they're platinum tipped or not. So that they match electrically.
One time I accidentally put in single platinum plugs (I think the plug boxes were labeled as double Platinums). Three plugs ended up wearing their gaps to double their original setting while three plugs were still at the original gap due to the current flow direction disparity.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
