New seat warmers, where to get the power? - JeepForum.com
post #1 of 28 Old 01-20-2015, 01:22 PM Thread Starter
mate44
Hi.
Just bought these seat heaters for my 99 mod: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Can I tap them into the cig socket? Will the fuse in the dash be able to handle the heaters and charging my phone/GPS at the same time?
Thanks,
mate44
mate44 is offline
post #2 of 28 Old 01-20-2015, 01:52 PM
Melissas6570
I just added them to my seats in a 00. If you look behind the glove box, you will find a small fuse panel. I had a fuse for rear defrost for a hardtop. I believe it was 20 amp. It may have been more. I used a fuse tap socked that I got from NAPA parts. I connected the 12 volt wires from the seat heaters to it, and pulled a ground from the metal frame that have the plastic dash mounted to it.
I DO IT WITH MY TOP OFF!
Melissas6570 is offline
post #3 of 28 Old 01-20-2015, 01:58 PM
willvogel1
^2. That is what I did.
willvogel1 is offline
post #4 of 28 Old 01-20-2015, 02:52 PM Thread Starter
mate44
Sounds like a good way to go.
Do you have a link to the fuse tap socket at NAPA?
Also, am I still able to use the defroster for the hardtop?
Is the circuit switched? Meaning it will follow the igniton?
Thanks,
mate44
mate44 is offline
post #5 of 28 Old 01-20-2015, 03:33 PM
4xfiend
4xfiend's Avatar
I tied mine into the cig lighter circuit. No issues with it. That's where the Mopar version gets the power from.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | Poison Spyder BFH rear bumper | Rokmen Mercenary rockers |
Originally Posted by Jerry Bransford
I DON'T FRIGGIN' CARE!!!
Originally Posted by Jim M
Please keep the facts to yourself; nobody here wants to hear them. This was a perfectly good internet argument until you came along with anecdotal evidence.
4xfiend is offline
post #6 of 28 Old 01-20-2015, 04:13 PM
Melissas6570
NAPA Part # NW 785135
http://www.napaonline.com/Catalog/Ca...135_0282529025
post #7 of 28 Old 01-20-2015, 05:17 PM
Jonny Jeep
Jonny Jeep's Avatar
In a 99 you should have two wires taped up near the fuse panel behind the glove box. A red/black unswitched wire from fuse 18 (15A) and a light blue wire from fuse 19 (20A) which also supplies the cig lighter/power outlet. The light blue wire would be ideal for powering the seat heater which are probably around 2.5-3A draw each. Typical draw draw for a phone charger would be up to 1 amp not sure what a GPS might require but probably in the region of an amp too so all well within the fuse rating and no problem running them all at the same time.
Jonny Jeep is offline
post #8 of 28 Old 01-21-2015, 05:33 AM Thread Starter
mate44
I will check this tonight!
mate44 is offline
post #9 of 28 Old 01-22-2015, 05:48 AM
phil823
i have those same seat heaters in my 97. i tapped into the cig lighter also..
my issue with them is, they take like 10-15 minutes to heat up!!! its quite annoying as i tend to be at my destination before hey get toasty.
if anyone have a fix for a slow heat up time im more than interested to hear it!
I have a Franken CHEEP! it hauls *** to fun places!
phil823 is offline
post #10 of 28 Old 01-22-2015, 01:50 PM Thread Starter
mate44
Do you have the exact same as i linked to in the first post? I read the reviews and there was many people claiming they where fast. I haven't received them yet and now I am worry they are no good. Are you pleased except the warm up time?
mate44 is offline
post #11 of 28 Old 01-23-2015, 07:30 AM
jski701
jski701's Avatar
I have these in my TJ and my truck, and they heat up in a few minutes, just remember that the heavier your clothes are the longer it will take to feel it. I start on high and within 5-10 minutes I have to switch to low because they get too hot... BTW, absolutely I love them.
Just some install info, I did the install myself, But I always have my buddy's car stereo shop hook up the power (I'm color blind, so lots of colored wires plus me = electrical fire) Anyway I always hook up to ignition to insure no possibility of power when not running.
jski701 is offline
post #12 of 28 Old 01-25-2015, 02:55 PM Thread Starter
mate44
Jonny Jeep was right. Found the wire, it was marked. I have unswitched and switched power to the right of the fuse panel. I think this is gonna be a easy install.
Thanks Jonny Jeep
mate44 is offline
post #13 of 28 Old 02-01-2015, 09:20 AM Thread Starter
mate44
I just found out that the switched cable (light blue) is labeled '3 amp max'
And not 20 amp as you stated.. Is there another cable behind the glove box?
mate44 is offline
post #14 of 28 Old 02-01-2015, 10:00 AM
Melissas6570
Hmmmm that's why I used the fuse block behind the glove box
post #15 of 28 Old 02-01-2015, 10:05 AM Thread Starter
mate44
Is it safe to tap into the defroster when I am currently using the hardtop defoster. Can it manage two additional seat warmers?
mate44 is offline
