New muffler question - JeepForum.com
 3Likes
post #1 of 25 Old 08-18-2017, 01:48 PM Thread Starter
lkvisser
Thinking about adding a magnaflow muffler to my 4.0, (have laying around). From what I read, most free flowing mufflers aren't too loud on a jeep. I'm just hoping for a little more tone, while driving.
The question is, what's the easiest way to do it? I haven't read anyone cutting the exhaust before the cat and after the muffler, and sliding it all out. Switch mufflers, and slide back in place and fasten?
Anything wrong with this theory?
Thanks for the help!!
Lance
Sent from my iPhone using Tapatalk
lkvisser is offline
post #2 of 25 Old 08-20-2017, 12:43 PM Thread Starter
lkvisser
Any help out there?
Thanks
lkvisser is offline
post #3 of 25 Old 08-24-2017, 08:09 AM
Ross
I would take it to a shop and have them weld it in.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #4 of 25 Old 08-24-2017, 08:31 AM
Deuxlatch
I like my Magnaflow sound. Not too loud but lets people know when I'm in a parking garage.
2005 LJ
2006 Wide Glide
"If you ain't the lead dog the scenery never changes"
Deuxlatch is offline
post #5 of 25 Old 08-24-2017, 08:33 AM
biffgnar
biffgnar's Avatar
It's been awhile since I looked at a stock exhaust, but I believe there should be a flanged connection with bolts between your cat and muffler. The muffler and tailpipe come off. Problem tends to be that the bolts in that flanged connection can get very rusty. If that happens you may have to start cutting. If you cut the flanges off a band clamp can be used to connect the pipes.
biffgnar is offline
post #6 of 25 Old 08-24-2017, 08:44 AM
Bigbob
Bigbob's Avatar
Lance
If the magnaflow you have is the right size, inlet and outlet and the inlet and outlet are in the correct position you simply measure and cut the pipe and install. If you can weld do so. If not clamps are fine. It's usually easier if you remove the tail pipe first. I would not mess with the flange as the bolts will probably break and you will more than likely have to get a new seal.
I've had my flowmaster clamped in for 10 years with no issue.
The sound will be just fine. The exhaust note from a 4.0 is pretty soft.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #7 of 25 Old 08-24-2017, 08:59 AM
RandyTJ
Save yourself some money.
I had my factory muffler removed 10 years ago and put a cheap glass pack on............still going strong.
A nice deeper tone and not that loud, also less back pressure.
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Goodyear 315/75/16 MTR's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
1999 XJ 6.5 Lift, Rusty's Long Arm, Four Link Rear Suspension, ARB Lockers Front and Rear, Alloy Axles....
RandyTJ is offline
post #8 of 25 Old 08-24-2017, 09:17 AM
TJnBC
Hushpower muffler by Flowmaster in all my 4.0l's
2006 LJR...the madness begins again
TJnBC is offline
post #9 of 25 Old 08-24-2017, 09:55 AM
jeep'd
jeep'd's Avatar
Here is a pic of my setup. Just had it out to replace my RMS. I cut it before the rear cat. I believe it's the Flowmaster HP2. Sounds good, not to loud but enough to make you get in the throttle a little more. The turn down is just after my UFC UHC TT. I don't think I can get it any more high clearance then this.
jeep'd is offline
post #10 of 25 Old 08-24-2017, 09:58 AM
jeep'd
jeep'd's Avatar
Oh, I think I paid about $115 for the muffler on Amazon. And a friend that owns a muffler shop installed it for free.
jeep'd is offline
post #11 of 25 Old 08-24-2017, 10:09 AM
Deuxlatch
Originally Posted by jeep'd View Post
Attachment 3445530
How the heck did you get to the flange bolts holding the pipe to the manifold? I couldn't get a socket on those, even with a u-joint adapter and long extension.
2005 LJ
2006 Wide Glide
post #12 of 25 Old 08-24-2017, 10:11 AM
biffgnar
biffgnar's Avatar
They are gettable this way from below. Keep trying.
biffgnar is offline
post #13 of 25 Old 08-24-2017, 10:12 AM
jeep'd
jeep'd's Avatar
I started from under neath with the flex joint, when putting them back it, I couldn't hit the same angle and actually found that if you remove the rubber flap(rear two plugs) it opens up enough room to get a wrench in there.
jeep'd is offline
post #14 of 25 Old 08-24-2017, 10:13 AM
jeep'd
jeep'd's Avatar
Sorry the rubber flap in the wheel well.
jeep'd is offline
post #15 of 25 Old 08-24-2017, 10:15 AM
jeep'd
jeep'd's Avatar
I'm also running a 1.25" BL and 1" MML.
jeep'd is offline
