new drive shaft/ pinion angle - JeepForum.com
post #1 of 4 Old 06-05-2020, 07:55 PM Thread Starter
dpw92007
taking measurements for a new tw drive shaft and I just want to make sure i am doing this correctly . thank you for any and all help. I included a pic of my jeep and the tw directions. Also not sure how to set pinion angle correctly , I just kinda guessed. 4 in lift
dpw92007 is offline
post #2 of 4 Old 06-05-2020, 10:26 PM
mukluk
mukluk's Avatar
The yellow line in your picture is correct for where you want to measure. Having the pinion roughly pointed at the rear transfer case output is close enough for the purpose of measuring for a driveshaft, once you install the new shaft you'll fine tune the pinion angle so that the operating angle of the u-joint at the differential is one degree or less, ie, the driveshaft will be straight in line with the pinion shaft. If you have bushings with a little give in the rear axle control arms, you may have to adjust the pinion a couple degrees nose down from there to allow for the axle housing torqueing up under load.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 4 Old 06-06-2020, 01:22 AM Thread Starter
dpw92007
Thank you. My upper arms are savvy w/Johnny joints, I am also planning on new buying lowers as cash flow permits, so if I understand correctly once I get the drive shaft installed and dial everything in I won’t have to account for torque as much?
dpw92007 is offline
post #4 of 4 Old 06-06-2020, 02:08 AM
mukluk
mukluk's Avatar
Good chance you'll be fine with the diff joint working angle set at one degree or less with JJ-equipped arms, but each Jeep can be different. The real tell will be if you get driveline vibration that goes away when you let off or ease up on the throttle -- that would indicate a bit more nose down pinion angle is needed.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
