In need of a new radiator - JeepForum.com
 17Likes
post #1 of 19 Old 08-14-2019, 09:17 AM Thread Starter
domolivia
Hello!
My Jeep Wrangler is a 2003 TJ 4.0L Rubicon.
I am currently wanting to replace my radiator since I believe that the factory radiator is still the one in my vehicle and I live in Arizona where the heat just ruins everything a little faster. And my Jeep has been running a little hot lately
I was looking at Rock Auto for a new radiator but they have like 20 different options to choose from and I have no idea which one would be best. I'm not wanting to break the bank but willing to spend the money if it's a quality item that will last.
Do y'all have any suggestions for me?
Thank you!
Dominique
domolivia is offline
post #2 of 19 Old 08-14-2019, 10:09 AM
BM3
BM3's Avatar
Another stock mopar one is what I'd recommend, your old OEM lasted 16 years.....
Wojoe and domolivia like this.
BM3 is offline
post #3 of 19 Old 08-14-2019, 10:17 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, stay with the OE Mopar which has an all aluminum core and cools better than the vast majority of aftermarket radiators. Not to mention most aftermarket radiators are cheaply made and rarely cool even nearly as well.
Jerry Bransford is offline
post #4 of 19 Old 08-14-2019, 05:05 PM
rcroane
While you're at it, consider replacing water pump, thermostat/housing, hoses and serpentine belt. Especially if you think any of these are original to your Jeep.
rcroane is offline
post #5 of 19 Old 08-15-2019, 12:27 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Nothing last longer than Mopar. I still have the original in my 99'.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5" BDS lift/ 33" DC extreme country MTs. JEEP #18
TheBoogieman is offline
post #6 of 19 Old 08-15-2019, 01:43 AM
AjRagno
AjRagno's Avatar
If I had to do it again, I would absolutely go with a Mopar radiator.
My original radiator failed a couple of years ago at around 175,000 miles. Without any previous issues, one day I came out to find it had completely drained onto my garage floor. I replaced it with a Spectra radiator from NAPA. About 18 months later, the Spectra radiator started leaking severely at the top seam; the sort of leak that would have required a tow if I were far from home. NAPA replaced it under warranty without issue but I fully expect this radiator to fail similarly at some point so I now keep the receipt in my glove box.
AjRagno is offline
post #7 of 19 Old 08-15-2019, 08:59 AM
Jerry Bransford
Administrator
Yep Spectre is not a good brand. A Spectre fuel pump I installed failed at 13 months, 1 month out of warranty.
TheBoogieman likes this.
post #8 of 19 Old 08-15-2019, 03:27 PM
TheBoogieman
Distubed Jeepaholic
Shame on you.
post #9 of 19 Old 08-15-2019, 04:21 PM
SkylinesSuck
I just want to be clear; there is no leak and you want to replace your factory radiator because you think it might still be the factory piece, and you have been running a little hot lately, right? If so, I suggest figure out why it's running hot. I'd start with a coolant flush/change, and take a look what the inside of the core looks like while it's empty.
No need to replace it if it's not leaking and/or plugged up/corroded on the inside. Many of the experienced guys on here swear by the factory stuff.
mukluk and domolivia like this.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #10 of 19 Old 08-16-2019, 10:30 AM
mukluk
mukluk's Avatar
Unless you're seeing degradation and cracking of the plastic tanks or other evidence of impending failure, I'd leave the current radiator in place and search as to what is causing your Jeep to run slightly hot. Very rarely do you hear of the stock radiators suddenly experiencing a catastrophic failure without warning signs beforehand, problems are normally indicated by seepage or leaking coolant long before things come apart sufficient to leave one stranded. I'd echo the advice to start with a good coolant flush and fill, making certain to get as much air out of the system before putting the radiator cap back on and adding fluid to the overflow tank.
domolivia likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #11 of 19 Old 08-17-2019, 08:29 PM Thread Starter
domolivia
Valid point, thank you!
post #12 of 19 Old 08-17-2019, 08:39 PM Thread Starter
domolivia
I don't want to replace it simply because the piece is old and is from the factory. I want to replace it because it's been giving me trouble. I've replaced the thermostat, the water pump, all the hoses and I have replaced the coolant multiple times and it still runs hot. I had a mechanic look at the whole cooling system including the electrical part of it and he found nothing wrong with the system but yet it still runs hot. My next logical step that I can think of would be to replace the radiator. This Jeep has lived in Arizona its whole life, and I know that radiator has taken a beating from the heat. Unless you have another suggestion because I have done just about everything to try and find the problem.
post #13 of 19 Old 08-17-2019, 08:40 PM Thread Starter
domolivia
Already got all of those done! Thank you for the advice though, it's much appreciated!
rcroane likes this.
post #14 of 19 Old 08-17-2019, 08:40 PM Thread Starter
domolivia
Very valid point! Thank you!
post #15 of 19 Old 08-17-2019, 08:42 PM Thread Starter
domolivia
Thank you, I did not know that about aftermarket radiators. It's such hit or miss with aftermarket parts!
