Need more help on radiator fan - JeepForum.com
post #1 of 3 Old 11-20-2011, 09:31 PM Thread Starter
MarshallMopar
Hi there. my radiator fan started making all kinds of noises. so i checked under the hood of my jeep. its the 4.0 i noticed when the jeep was off i could wiggle it. after that i tried to spin it and as i spun it, it got reall rough then itd be kinda smooth. and when i gave it gas you could hear it just make all kinds of high pitched noises. Then i went to spin my buddys fan in his 4.0, and its was a nice smooth spin with not a noise at all. i was told two different things. i needed a fan. and the other one was i needed a fan clutch? it feels like the bearings in it are completely shot. If anyone could clear me up on maybe exactly what i need it would be greatly appreciated!
"Jack Em High, Fat Girls Cant Climb"
MarshallMopar is offline
post #2 of 3 Old 11-20-2011, 09:34 PM
chris142
The fan blade bolts to the fan clutch that bolts or screws onto your water pump. You need a fan clutch.
chris142 is offline
post #3 of 3 Old 11-20-2011, 09:51 PM
2jhanna
MarshalMopar, with the info given in your other thread on the same subject, and with the comparison of your buddy's Jeep, you should be able to determine if the fan is bad, or as we suggested in your last thread, probably the clutch.
The clutch should not spin or make noise. But should have even drag/resistance as you rotate the fan by hand.
Or your water pump bearing may be shot causing the entire assy to wobble and have play.
Either way you going to have to start taking things apart, fan, clutch, water pump. Stop when you get to the bad part.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is online now
fan , noise , radiator
radiator leak. get the radiator fixed or replace? LiveAndLearn TJ Wrangler Technical Forum 32 11-24-2011 10:06 AM
Radiator Barn-Single row radiator freeskier93 TJ Wrangler Technical Forum 17 08-23-2010 01:35 PM
2 row aluminum radiator thats NOT from radiator barn LMG23 TJ Wrangler Technical Forum 3 03-15-2010 11:58 PM
Changed Radiator Cap. My Radiator EXPLODED blubaru2002 TJ Wrangler Technical Forum 8 08-11-2009 04:42 PM
Radiator Barn radiator rocks! Jim Shanks TJ Wrangler Technical Forum 10 12-08-2003 12:26 PM
