Need help on oil sending unit - JeepForum.com
 4Likes
post #1 of 17 Old 07-13-2020, 09:32 AM Thread Starter
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
Fellas
When I bought the jeep ( about 1 year ago ) the oil pressure always stayed pegged. I knew right away that I didnt always have 80 PSI and that it was a indication of a bad sender. So I went down to NAPA and got one there. That fixed it ( or so i thought )-- pressure returned to normal ( aprox 50 psi ). Well that lasted a few months, then it went backed to pegged. Suggestion was made to go the OEM route-- so I did @ TRIPPLE the cost, about $80 if I remember correctly. Pressure returned to normal untill today as its backed to being pegged. Now I know ABSOLUTELY NOTHING about the electrical side of anything, but I am thinking that there is to much voltage going to them and ruining them.
What do you guys think?
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #2 of 17 Old 07-13-2020, 10:09 AM
jtec
jtec's Avatar
2014 JK Wrangler
this is a 5v sensor, see attachment.
Are you getting any codes? Might want to scan - do not rely on CEL only.
Is airbag light on?
BlueFl.Wrangler likes this.
jtec is offline
post #3 of 17 Old 07-13-2020, 05:45 PM Thread Starter
BlueFl.Wrangler
Supporting Member
Is airbag light on?
Thanks for chiming in
No C.E.L.'s in the dash---- hooked up scan tool , shows no codes
The air bag is lit up "off "
Winston Churchill
post #4 of 17 Old 07-13-2020, 06:04 PM
2jhanna
With the jeep running, and somebody in the cab watching the gauge, can you move/wiggle the wire lead and harness around
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #5 of 17 Old 07-13-2020, 06:06 PM Thread Starter
BlueFl.Wrangler
Supporting Member
Fixing to give it a try
Winston Churchill
post #6 of 17 Old 07-13-2020, 06:13 PM Thread Starter
BlueFl.Wrangler
Supporting Member
nothing changed
still pegged
Winston Churchill
post #7 of 17 Old 07-13-2020, 07:22 PM
2jhanna
Sorry, worth a try.
jhanna
denton county, tx
2jhanna is offline
post #8 of 17 Old 07-13-2020, 08:10 PM Thread Starter
BlueFl.Wrangler
Supporting Member
Always worth a try
Didnt cost a dime
Winston Churchill
post #9 of 17 Old 07-13-2020, 11:15 PM
mukluk
mukluk's Avatar
Unplug the connector and give the connector and sender terminals a good shot of spray electrical contact cleaner (maybe the issue is just a bit of schmutz causing headaches). Key off, you should see less than 5 ohms resistance when checking continuity to chassis ground on pin 3 (BK/LB), there should be more than 100 ohms when checking continuity to chassis ground at pin 2 (GY/YL), and more than 100 ohms when checking for continuity from pin 2 to either pin 1 or pin 3 (checking for shorts from wire to wire). Key on and engine not running, you should see between 4.8 and 5.2 volts at pin 1 (VT/OR). If everything checks out, make sure none of the terminals in the connector are loose or recessing, then reconnect the plug and see if the sender works.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 17 Old 07-14-2020, 06:38 AM Thread Starter
BlueFl.Wrangler
Supporting Member
When you say chassis ground- you dont mean a specific point do you? Just a good clean area on frame or block should do--?
Winston Churchill
post #11 of 17 Old 07-14-2020, 09:09 AM
mukluk
mukluk's Avatar
Yep, a clean spot on the frame or block should do, the battery negative terminal is also acceptable, just didn't want you using the ground wire in the sender connector as a ground in case it was shorted to another wire.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #12 of 17 Old 07-14-2020, 10:13 AM
jtec
jtec's Avatar
2014 JK Wrangler
KOEO - WHAT DOES GAUGE READ?
EXplain (The air bag is lit up "off ") IDK is the light ON or not?
If its on check the ground circuits for stray voltage - advise.
jtec is offline
post #13 of 17 Old 07-14-2020, 11:48 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Have some patience here with me
KOEO- is that key on engine off?
Winston Churchill
post #14 of 17 Old 07-14-2020, 02:01 PM
jtec
jtec's Avatar
2014 JK Wrangler
yes Key On Eng Off.
A quick look to see if wiring an issue. It should be at 0zero
I really do not understand your answer to AIRBAG light... Is it on?
jtec is offline
post #15 of 17 Old 07-14-2020, 04:33 PM Thread Starter
BlueFl.Wrangler
Supporting Member
Nope-- not @ zero- its pegged KOEO
Winston Churchill
