Need Ford 8.8 write-up - JeepForum.com
post #1 of 2 Old 07-31-2010, 10:34 AM Thread Starter
monjorrow
Well i finally busted my D35, so I picked up an 8.8 the other day and im ready to put it in. I want to make my own brackets, mostly because I dont feel like shelling out $250 for a kit. So im looking for a write up on how to install and make the brackets but my searching is not turning up anything.
And I was also wondering what you guys are doing about your driveshafts? Buying a new one? Getting your stock one re-fitted?
monjorrow is offline
post #2 of 2 Old 07-31-2010, 10:42 AM
cmyTJ
cmyTJ's Avatar
Ford 8.8 Axle Install - 1
I had my 8.8 built since I cannot weld but this write-up has a lot of what you are looking for.
I am adding a SYE and CV driveshaft to mine. The driveshaft is a front XJ shaft that a local shop is cutting down for me.
cmyTJ is offline
ford 8.8 , write-up
Ford f-150 shock towers up front- Mini write-up Bennettj13 TJ Wrangler Technical Forum 65 11-06-2011 03:39 AM
which axle?? Ford 8.8 or Ford 9" tcoche TJ Wrangler Technical Forum 31 07-19-2010 11:31 PM
Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up barry1me TJ Wrangler Technical Forum 14 06-29-2010 07:32 AM
Ford SVO disk brake kit on Ford 8.8 texashoghunter TJ Wrangler Technical Forum 0 07-10-2008 07:12 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
