Need advice about axles and gearing! - JeepForum.com
post #1 of 10 Old 08-29-2014, 06:46 PM Thread Starter
WillysJeep22
Hello everyone! I'm going to start off by thanking everyone in advance for any advice or input given . So here's my situation. I have an 04 jeep wrangler x, straight 6 4.0, 5 speed. I have a 3" BDS suspension lift with a transfer case drop, sway bar discos, 33x12.5 pro comp extreme AT... ect. Now here's my plan, since I have the awful 3.07 gearing and a D35, I intend to regear to a 4.56 or 4.10 (still on the fence but leaning towards 4.56), front and rear Detroit truetrac LSDs, and upgrading the D35. Now I understand that superior is out of business, is there any other D35 upgrade kits that would be comparable? And is there anything else that I should also add or add to the wish list? This is my DD and I only do light to moderate wheeling. Just trails and minimal mud. Remember this is my DD so I'm not doing anything that increases the risk of a major disaster. Just want to be very capable. I'm not going to do a 8.8 swap and I'm not spending a fortune on a D44 (I've looked everywhere). There is a very very little chance I will go above 33s, and if I do it'll only be 35s. Oh, and is a SYE worth it? I have no problems at the moment on the road except a slight shimmy between 45-55 but only like 50% of the time. Quite strange that it happens sometimes and straight as an arrow the other. Again thanks again for any imput. Let me know if you have any questions on my setup.
-Will
WillysJeep22 is offline
post #2 of 10 Old 08-29-2014, 07:03 PM
biffgnar
biffgnar's Avatar
-Will
The reason you have no vibes and question an SYE is because you have a TC drop. Wouldn't you like to improve your belly clearance?
biffgnar is offline
post #3 of 10 Old 08-29-2014, 07:56 PM
1ofakind
If it's on the road 90 percent of the time I wouldn't worry about the vibe if you don't care but yes a sye would be the way to cure that
1ofakind is offline
post #4 of 10 Old 08-29-2014, 07:58 PM
biffgnar
biffgnar's Avatar
It would? He's describing a steering wobble not driveline vibes.
biffgnar is offline
post #5 of 10 Old 08-29-2014, 08:00 PM
durango-bob
durango-bob's Avatar
2006 WK
The money that you spend on regearing, locking, and "upgrading" your D35 will just about pay of a drop in D44 built to your specs. I know that you said that you don't want to spend a fortune on a D44, but it's even worse spending it on a D35.
durango-bob is offline
post #6 of 10 Old 08-29-2014, 08:02 PM
1ofakind
Ooooops miss read that haha sorry
1ofakind is offline
post #7 of 10 Old 08-29-2014, 08:22 PM
joe_jeep
For 33s the true trac and quality 27 spline shafts will b fine.
But that is about $200 for gears, $400 true trac, $300 shafts.
U can get a d44 for under $900, but its limited slip is not as good.
Either will work fine for you. Price will should b the bottom line in this case.
The 35 beefed up will have better gound clearance, b lighter, with a better limited slip.
The 44 has a stronger ring and pinion, slightly stronger housing.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #8 of 10 Old 08-29-2014, 08:47 PM Thread Starter
WillysJeep22
Yeah I'm not too worried about the vibration. So the SYE will only give me more ground clearance because I can raise my TC back to position? And like I've said, I've looked all over for a D44 and again too expensive and I'd still have to regear aand install the LSD. I've read the beefed 35 is comparable, if not stronger than a stock 44. And I'm not rock crawling so I really don't need all the strength in the world. I'm only running 33s. And where would you all recommend buying all this from? Is there somewhere I can kit all the gears and D35 axles together? Also what about brands? Thanks again for all your all's input.
post #9 of 10 Old 08-29-2014, 08:58 PM
joe_jeep
When Beefing the 35 many use what is called a super 35 kit.
it is a locker, 30 spline chromo shafts, and a special master install kit.
For brands look at ten factory, nitro, yukon, and alloy.
It will be around a grand.
There is no true trac for that kit though.
the super kit is offered with a detroit, arb, or ox lockers.
all fine products, but kinda overkill for u, and not as street friendly.
Buy a true trac and 27 spline 10 factory shafts.
Should be 650 to 750 for both.
glfwda #6624
joe_jeep is offline
post #10 of 10 Old 08-29-2014, 09:21 PM Thread Starter
WillysJeep22
OK so I will only need to buy the poly crom shafts to help out the D35? And is it possible to increase the spline or will that even be necessary? And no I don't want to lock either axles. Well I would like to have selectable lockers but way to expensive for my budget and a bit unnecessary for my usage. I feel the truetrac is my best bet.
dana 35 , gearing , jeep tj , lsd , sye
