My plans to fit 35's - will it work? - Page 3 - JeepForum.com
post #31 of 43 Old 08-03-2010, 04:43 PM Thread Starter
alex_c
I have a line on a HP d30 with ARB, 30 spline chromos and 4.56 gears for $700.
I'm thinkin either re-gear the 8.8 (4.10) or swap the goodies into a TJ housing with 4.10 gears.
I wish I had $20,000 lying around so I could stop being forced to make decisions!!!!!
alex_c is offline
post #32 of 43 Old 08-04-2010, 12:57 PM
MrGipe
MrGipe's Avatar
2015 JK Wrangler
I just got my 35s on today
2.5" SL, 1.25" BL...
Now-15 JKU Anvil
Then-02 TJ Patriot Blue
University of Kentucky
MrGipe is offline
post #33 of 43 Old 08-04-2010, 02:12 PM Thread Starter
alex_c
those tires are sexy
alex_c is offline
post #34 of 43 Old 08-04-2010, 10:11 PM
themcfarland
Originally Posted by DH19922010 View Post
Imped clears 35's with a 3in coils up front, 2.5in rear, and 1.25 bl as well as some fender trimming. You will need to adjust your bumpstops so it won't rub. It can be done. i run 33's with 3in of lift and a 1in bumpstop extension with no rubbing at all so 4in of total lift (bl and coils) plus 2in of bumpstop should be fine.
I see some folks with odd length coils.. 3 in front and 2.5 in back..
What company does that?
I am looking to buy a tried , true and proven lift and you guys are talking me into something...
thanks in advance..
themcfarland is offline
post #35 of 43 Old 08-05-2010, 02:47 PM Thread Starter
alex_c
Rusty's sells 2", 3", 4" coils separately. I'm sure other suspension manufacturers do as well. You can also use spacers to level it out. Lot of people put more lift in the front to account for the rake that Wranglers have naturally, and the added weight of bumpers, winches etc. I don't have a winch or bumper right now, but the 8.8 will lift the rear end up about 5/8" in the rear, so I need to account for that. I'm guessing a 2" lift in the rear and a 3" lift in the front will be good. I can always play with spacers to level it out perfectly.
alex_c is offline
post #36 of 43 Old 08-05-2010, 02:54 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Until you load up for the trail and then you look like a stinkbug running in reverse while you blind everyone with your too high headlights.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #37 of 43 Old 08-05-2010, 03:06 PM Thread Starter
alex_c
HAH
It looks like that when it's loaded even without the spacers now!
And regardless, all that gear is gonna come out before I start hitting the real trails.
alex_c is offline
post #38 of 43 Old 08-05-2010, 04:27 PM
crgrissom
Master of Reality
crgrissom's Avatar
HAH
You might at least want to measure your 'rake' with your butt in the driver's seat and a passenger. If you make it perfectly level when parked, you might not like it when you're in it.
I guess it depends on where/how you like to take your pictures...
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #39 of 43 Old 08-05-2010, 05:07 PM Thread Starter
alex_c
Chuck
Good call. Like I said, I can play around with temporary shims and stuff to figure out what stance works the best loaded and unloaded. Then just cut the spacer to whatever thickness it needs to be.
alex_c is offline
post #40 of 43 Old 08-05-2010, 06:45 PM
rs4race
I was running level with full interior, hardtop and trail gear. That was with 2.5" lift. Now its closer to 3" or 3.5" lift in the rear as i have nothing in the jeep. Sometimes I have thoughts of relocating shocks and either a bodylift or highlining the metalcloaks and inch or so. I think it would be nice to get the flex and travel from 12" shocks all around but don't want to lift it more than it is..
My Build
https://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #41 of 43 Old 08-05-2010, 07:52 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
4" springs in the front (2,300 lbs axle weight) and 5" springs in the rear (2,700 lbs axle weight). Works for me...
Gone but not forgotten.
Knuckelhead is offline
post #42 of 43 Old 08-05-2010, 08:28 PM
rs4race
Are you saying you jeep weighs 5000lbs?
My Build
rs4race is offline
post #43 of 43 Old 08-05-2010, 08:45 PM
Knuckelhead
R.I.P. Knuckelhead
Yep, without me in it and a full tank of gas., It weighed 5,030 lbs before the Savvy gas tank skid..
35 , tires , lift , suspension , advice , help , mod , modification
Will my set up work with 35's..? Dave0392 YJ Wrangler Technical Forum 7 12-29-2008 01:13 AM
FT 4" Flex Arm & 35's work? GlennH TJ Wrangler Technical Forum 2 01-02-2007 04:45 PM
TJ 4.0l Power Plans (Edge Trail Jammer, perhaps header/ exhaust work.. maybe regear?) selmo_yidna TJ Wrangler Technical Forum 32 10-31-2006 04:31 PM
future plans for 35's FanAholic TJ Wrangler Technical Forum 2 05-12-2004 07:32 PM
Want 35's, will this work? rubberbelly YJ Wrangler Technical Forum 9 03-20-2003 07:12 PM
