My plans to fit 35's - will it work? - Page 2 - JeepForum.com
post #16 of 43 Old 07-29-2010, 03:23 PM
kennyboobear
kennyboobear's Avatar
Originally Posted by alex_c View Post
Highline is out of my budget as of this point in time.
I wasn't referring to an AEV highline, I was referring to doing it yourself with a flat fender kit. Smittybilt (yea yea, rant and rave all you want) flat fenders with no flare are 299, and the cost of doing your own highline is damn near null if you already have the tools to do it with. You end up with as much clearance as you would using metalcloaks (albeit nowhere near as sexy as metalcloaks) for much less.
SILVER JEEP CLUB MEMBER #46
Get
Originally Posted by GraKee99 View Post
Driving on snow is a lot like sex, it's a lot of fun but if you don't pay attention, you can really mess up someone's rear end.
Originally Posted by Gene Mooneyham
Not to burst your bubble, but California gets worse every year. Liberals, and illegals have ruined any chance California had to get turned around, it's a sinking ship.
kennyboobear is offline
post #17 of 43 Old 07-29-2010, 05:20 PM Thread Starter
alex_c
Yeah, it's an option, I've seen some OK DIY highline, lots and lots of CRAP DIY highlines, and maybe like one or two that actually looked professional, and the amount of time and effort involved in doing it properly is not something I am interested in at this point in time.
alex_c is offline
post #18 of 43 Old 07-29-2010, 06:02 PM
DH19922010
Imped clears 35's with a 3in coils up front, 2.5in rear, and 1.25 bl as well as some fender trimming. You will need to adjust your bumpstops so it won't rub. It can be done. i run 33's with 3in of lift and a 1in bumpstop extension with no rubbing at all so 4in of total lift (bl and coils) plus 2in of bumpstop should be fine.
DH19922010 is offline
post #19 of 43 Old 07-29-2010, 06:09 PM
Imped
Imped's Avatar
Not anymore. Running untrimmed standard TJ flares. I see no reason to go taller than that on short arms.
OlllllllO
IndyORV
Imped is offline
post #20 of 43 Old 07-29-2010, 08:35 PM
jforse
jforse's Avatar
Im also running this setup with no issues.
jforse is offline
post #21 of 43 Old 07-29-2010, 08:48 PM
Photog2000
I have 3.5" in front and 3 inches out back running 35" KM2's.
I say run what you want. If it brakes fix it. If it doesn't you just saved 2 G's. If I disconnect my sway bars and wheel really hard they will rub. Guess what? It is plastic and rubber!!! Who cares if they rub a bit!!!
Photog2000 is offline
post #22 of 43 Old 07-29-2010, 10:22 PM
DH19922010
I didn't know that. lol. Why'd you change? I always liked the trim you did. looked very clean. Your whole jeep build looks clean and seems to work awesome
post #23 of 43 Old 07-29-2010, 10:33 PM
Imped
Imped's Avatar
I got tired of trimming and didn't want to put forth the effort on my current set when it doesn't functionally gain me anything. I actually think they look better untrimmed anyway. The next round of pictures on my thread will show them.
OlllllllO
IndyORV
Imped is offline
post #24 of 43 Old 07-29-2010, 10:38 PM
Photog2000
EXACTLY!!!!! It hurts nothing if the tire rubs them, and I too think they look much better if left alone. The only purposeof trimming the flares is to give the illusion of a taller lift. Nothing more.
post #25 of 43 Old 07-30-2010, 01:38 PM Thread Starter
alex_c
Thanks for the input guys. It really seems counter intuitive to put a huge lift on a narrow, SWB vehicle. Bigger tires are obviously better, but 6-8" of lift on a TJ??? No thanks. I'd rather rub flares than get a full monty of the under carriage when I'm scratching my head trying to figure out how to get the shiny side back UP. Anyone who lives in the mountains can attest to that. Most of our trails are really steep here in BC.
alex_c is offline
post #26 of 43 Old 07-31-2010, 11:00 AM
Photog2000
I can recall at least 3 times now where I would have been on my side if I had the "required" 6 inch lift "needed" to run 35's. My 3 inches does me just fine.
post #27 of 43 Old 07-31-2010, 02:40 PM
inglisleslie
Metal Cloak and some rear corners with extended wheel wells...Like in my pic. I am going to run 35"s and could have done it with no lift. I added the OME 2.5" just for the better ride...but i am trying to keep the jeep as low as possible
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> https://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #28 of 43 Old 08-01-2010, 02:19 AM Thread Starter
alex_c
Sweet, I'd love a set of those but $$$$
alex_c is offline
post #29 of 43 Old 08-02-2010, 06:42 AM
UncleWilson
UncleWilson's Avatar
So my original build plan was for 33's..but I figured with the 8.8 swap, 35's might be better.
I'm going to do a 3" coil up front and 2" spacer in the rear with a 1" BL/MML and trimmed flares. SYE, and Currie arms will also be going in. I already have longer shocks, bumpstop extensions, and extended sway bar links.
The front axle will be a D30 with 4.10 gears. The rear is a 8.8 w/LSD and 4.10 gears.
I plan on (eventually) going up to 4.88's with an HP D30 up front, but that's not in the budget right now. 4.10's and 35's isn't perfect but it's still better than the 3.07's and 31's I'm running now.
I will be getting an adjustable track bar for the front, and maybe an adjustable one for the rear, depending on whether or not the height of the aftermarket 8.8 track bar bar bracket is much higher than the stock one (plus the added height of the axle tube etc)
Brakes will probably be centric rotors with EBC pads and steering will get an v8 ZJ tie rod.
Oh, and I'm torn between KM2's and MT/R Kevlars. Leaning towards the goodyears as they apparently have good road manners and are longer wearing (this jeep will be a DD)
I'm in the same boat. Only thing I can think of that you don't have is axle shafts, but I don't know what's in the 8.8. The rest sound good. Like i said very similar to what i'm planning (Currie 4", 1.25 BL, 1" MML, Blisten Shocks, Rokmen Armor, 35's, Upgraded brake pads. Not sure about axle shafts yet, but will probabaly drive it till it breaks)
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 37" BFG KO2, Method 307, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #30 of 43 Old 08-02-2010, 05:54 PM
Photog2000
Good Call!!!!! If it ain't broke don't fix it. There is a chance you may never break the thing. Look at the money saved. My D35 is working just fine right now.
35 , tires , lift , suspension , advice , help , mod , modification
Will my set up work with 35's..? Dave0392 YJ Wrangler Technical Forum 7 12-29-2008 01:13 AM
FT 4" Flex Arm & 35's work? GlennH TJ Wrangler Technical Forum 2 01-02-2007 04:45 PM
TJ 4.0l Power Plans (Edge Trail Jammer, perhaps header/ exhaust work.. maybe regear?) selmo_yidna TJ Wrangler Technical Forum 32 10-31-2006 04:31 PM
future plans for 35's FanAholic TJ Wrangler Technical Forum 2 05-12-2004 07:32 PM
Want 35's, will this work? rubberbelly YJ Wrangler Technical Forum 9 03-20-2003 07:12 PM
