my new to me TJ, front end problem - JeepForum.com
post #1 of 10 Old 06-27-2010, 06:22 PM Thread Starter
FLYKELLEY
Hi Gang
Bought a one owner 97 TJ with 110K on it. It has a 2 1/2 rancho lift kit on it with 33 x 9.5 on factory wheels. Drove fine until it got to 57 MPH then could not hardley keep it on the road. Shook like hell from 57 to about 61 then smoothed out for the most part. I know I have a broken rear coil spring, not sure if that will effect the front end or not. Looking for someplace to start.
Thanks Mike
FLYKELLEY is offline
post #2 of 10 Old 06-27-2010, 06:55 PM
Prryan45
Prryan45's Avatar
You found the problem or one of them.That thing has rusted bad.Your missing a bumpstop also.
Prryan45 is offline
post #3 of 10 Old 06-27-2010, 06:56 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Check everything for wear/excess play and have the tires balanced. It's a start and will rule out alot. Also, it's not related, but in your first pic it looks like you're missing a bumpstop.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 10 Old 06-27-2010, 07:20 PM Thread Starter
FLYKELLEY
Hi What has rusted bad?? Anything stands out besides the missing bumper stop?
Thanks Mike
post #5 of 10 Old 06-27-2010, 07:37 PM
Prryan45
Prryan45's Avatar
Thanks Mike
I meant the underside of the Jeep has rusted bad but I see it is a snow plower.You need a new spring and you have a bumpstop missing.
Prryan45 is offline
post #6 of 10 Old 06-27-2010, 07:42 PM Thread Starter
FLYKELLEY
Hi Prryan, yes it came from Northern Michigan. The front end parts are rusty. Im thinking of dropping it back down some and using smaller tires. I have all summer to get this ready for the winter as it will be my driveway jeep. I also have a Yj and its a great truck for driveways.
Regards Mike
post #7 of 10 Old 06-27-2010, 07:54 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Didn't you notice that you have a broken spring?...
Gone but not forgotten.
Knuckelhead is offline
post #8 of 10 Old 06-27-2010, 08:07 PM
robncar
robncar's Avatar
Usually, a vibration that has a related speed band can be tire balance, in your case 57 to 61MPH. Many folks have found that TJ's need tires to be as close to 0/0 balance as possible. One way to test is to swap the front tires to the back and see if the vibration changes. The rear spring may have failed due to not only rust but from coil bind from the missing bumpstop. If it were my Jeep, I think I'd go through the suspension and replace anything questionable. I wouldn't drive at speed with that broken spring.
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #9 of 10 Old 06-28-2010, 03:07 AM Thread Starter
FLYKELLEY
Yes Knucklehead I was aware of the broken spring, its one of the first things to be replaced.
Mike
post #10 of 10 Old 06-28-2010, 06:43 AM
mdm
Farm Wheeler
… Looking for someplace to start…
Quit driving the vehicle until the spring is replaced.
Replace both rear springs.
Replace missing bump stop.
Balance tires.
Thoroughly inspect all suspension components and replace as necessary.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
front end , shaking
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 09:34 AM
Front End Problem brrempel TJ Wrangler Technical Forum 4 02-05-2006 05:49 PM
Front DS Problem sentinal02 YJ Wrangler Technical Forum 19 03-13-2005 08:58 AM
front hub problem sailor77 YJ Wrangler Technical Forum 2 02-06-2005 04:59 PM
Front end problem? GPERSCREEPERS99 TJ Wrangler Technical Forum 2 12-29-2004 01:41 PM
