Mopar Radiator - Quick Disconnects? - JeepForum.com
 1Likes
  • 1 Post By 53flattie
post #1 of 10 Old 11-17-2021, 06:26 PM Thread Starter
53flattie
53flattie's Avatar
1936 CJ2A
Ordered a new Mopar radiator. It has the quick disconnects for the transmission lines. The problem is - my trans lines have threaded fittings. Is there any way to make this work? Or am I going to have to return this radiator?
RockAuto only lists the one with the disconnectsÖ.
Sent from my iPhone using Tapatalk
53flattie is offline
post #2 of 10 Old 11-17-2021, 08:24 PM Thread Starter
53flattie
53flattie's Avatar
1936 CJ2A
Old fittings:
New radiator:
post #3 of 10 Old 11-17-2021, 08:34 PM Thread Starter
53flattie
53flattie's Avatar
1936 CJ2A
Perhaps someone sells a barbed quick-disconnect fitting that I can put in the radiator, then just clamp the rubber transmission lines to that?
post #4 of 10 Old 11-18-2021, 09:28 AM
JFM626
JFM626's Avatar
maybe you will find something here
https://www.speedwaymotors.com/Jiffy...ale,44521.html
How can you trust an atom, they make up everything
JFM626 is offline
post #5 of 10 Old 11-18-2021, 09:41 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
I googled "male QD to barb adapter" and turned a brazillion results. They exist. Your key is identifying what type of QD Mopar used. I could make a guess by your picture, but I'd bet I'd be wrong.... You could also check out Earl's - you could surely make your own adapter line with the proper fittings on each end for your application....
https://www.holley.com/brands/earls/
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #6 of 10 Old 11-18-2021, 02:32 PM
222Doc
222Doc's Avatar
Funny thing happened to friends Tj in our club on the trail. Needed a rad as the stock one failed. sent one jeep out to find a rad in town near. what they brought had same issue. had to trailer the jeep out. simple should have been.......
222Doc is offline
post #7 of 10 Old 11-19-2021, 08:09 AM Thread Starter
53flattie
53flattie's Avatar
1936 CJ2A
Thanks for all the responses. Unfortunately, with this much uncertainly around exactly which QDís Mopar used, I donít want to mess around with a brand new radiator and lose the ability to exchange it.
So Iím just going to send it back and get one for a 2004 - which doesnít use the QDís.
Still have no idea why this 2006 doesnít have QDís, unless the PO changed them out, for some reason (the old radiator is a Mopar unit, with the serpentine routing diagram sticker, so I assumed it was original).
TheBoogieman likes this.
post #8 of 10 Old 11-19-2021, 08:14 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Maybe the PO did it because the QD's confuse a lot of people and they break stuff.
p.s. My 99' had QD's. The replacement radiator had the same.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #9 of 10 Old 11-19-2021, 08:15 AM
TheBoogieman
Thanks for all the responses. Unfortunately, with this much uncertainly around exactly which QD’s Mopar used, I don’t want to mess around with a brand new radiator and lose the ability to exchange it.
So I’m just going to send it back and get one for a 2004 - which doesn’t use the QD’s.
Still have no idea why this 2006 doesn’t have QD’s, unless the PO changed them out, for some reason (the old radiator is a Mopar unit, with the serpentine routing diagram sticker, so I assumed it was original).
I'd return it while you can too. My 99' had QD's. The replacement radiator had the same.
post #10 of 10 Old 11-25-2021, 06:13 PM
rockcrawlin
rockcrawlin's Avatar
Maybe this. And a hose clamp on the rubber part of the line.
2005 Jeep Wrangler Rubicon Unlimited (LJ) 4.0L / 42RLE
rockcrawlin is offline
