modifying stock transmission mount? - JeepForum.com
 1Likes
  • 1 Post By Knuckelhead
post #1 of 11 Old 06-30-2010, 09:14 AM Thread Starter
viperbluelx
viperbluelx's Avatar
1980 CJ7
I've found threads mentioning that some have modified their stock transmission mount to lower the transmission down some into the stock skid. I'd like to drop mine 1/2"-3/4"(depending on clearance). Does anyone have any idea how to go about this?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #2 of 11 Old 06-30-2010, 09:36 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
if you can figure out a way to get rid of the transmission mount itself and keep the rubber mount in place, that would get rid of about 3/4".
or maybe cut off the top part [the part with the bigger holes to accommodate a socket]. grind down the heads of the two bolts that hold it in place. then drill some holes in the rubber. that would give you about 1/2".
Mail crawling.
MisfitSeven is offline
post #3 of 11 Old 06-30-2010, 09:50 AM
IslandTJ
PM Knuckelhead, I recall/believe he did this mod.
Now Jeeping in Oregon
IslandTJ is offline
post #4 of 11 Old 06-30-2010, 11:33 AM
bobthetj03
bobthetj03's Avatar
If you got $100 burning a hole in your pocket, you could get one of these and gain 1".
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #5 of 11 Old 06-30-2010, 05:24 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Yes I did, I cut 3/4" out of the body of the mount and welded it back together. Lowered the cat hanger also. This was for my BU to keep the exhaust pipe from hitting the front right, upper frame control arm mount.
I still use the OEM style replaceable mount. I'm still using all the OEM bolts...
Gone but not forgotten.
Knuckelhead is offline
post #6 of 11 Old 06-30-2010, 05:38 PM
Hesher420
Hesher420's Avatar
Do you have any pics, or a write-up of what you did there?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #7 of 11 Old 06-30-2010, 07:00 PM
Knuckelhead
R.I.P. Knuckelhead
Sorry . I'm not at home (deployed, sorta) and that's the only pic I have available to me for that mod. If you pull the whole mount out, I think you'll get the idea of how to cut the frame of the mount and weld it back together. A few others on this forum have done the same thing, maybe they'll chime in?...
post #8 of 11 Old 07-01-2010, 08:19 PM
Hesher420
Hesher420's Avatar
^Thanks, I'll have to take a look at it. I think I still have a spare mount laying around, so it'll be easy to look at.
post #9 of 11 Old 07-22-2010, 04:10 PM Thread Starter
viperbluelx
1980 CJ7
I ordered just a replacement transmission mount from Autozone thinking this would be the part I need to modify. Clearly this isn't what yall are talking about.
post #10 of 11 Old 07-22-2010, 04:31 PM
Knuckelhead
R.I.P. Knuckelhead
That doesn't look like OEM mount that I modified?
pdltrk likes this.
post #11 of 11 Old 05-19-2012, 09:48 AM
aparke4
aparke4's Avatar
any more input on this?
I have a ax5 and UCF TT ultra skid and the lo pro mount does not work... I am looking to get rid of my t case drop and utilize the entire skid clearance... i have to have the drop b/c my sye/ cv shaft angle is 22-23 degrees with out it
if i could modify the mount and gain 3/4 inches i would feel comfortable getting rid of the drop.
aparke4 is offline
tranny , transmission , stock skid , mount , modifying , modify , modification
Where to buy stock TJ wrangler transmission mount ? LMG23 TJ Wrangler Technical Forum 13 09-26-2011 01:44 PM
Modifying stock tailgate to drop down wmeyer116 TJ Wrangler Technical Forum 44 04-09-2011 12:30 PM
modifying stock seats rubiwannabe TJ Wrangler Technical Forum 2 09-06-2008 08:20 AM
Modifying Stock License Plate Holder for Relocation ryobi TJ Wrangler Technical Forum 3 10-25-2007 12:46 PM
Plans for Modifying rear tire mount to fit 33" tire BADEAGLE TJ Wrangler Technical Forum 10 11-02-2006 11:01 AM
