Missing bolt - Page 2 - JeepForum.com
 2Likes
post #16 of 19 Old 07-16-2020, 03:00 PM
2jhanna
Originally Posted by Mongo01tj View Post
It's not a through-hole. The two on either side are, but the lower one isn't. Threads into the housing. I agree, not sure how important it is, but I am seeing a seep of fluid from that spot. I've cleaned everything I can reach to determine if it's the rear main seal, which is my suspicion.
Sorry, you are correct, not a through hole. I just finished my rear main seal and "have been" it that area very recently. Either way, I don't think it's real picky if you did want to try a tap, even if you did have to make a trough hole.
Good luck on your leak correcting. For the past several months I've been all around and under mine fixing leaks.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #17 of 19 Old 07-16-2020, 03:42 PM
2jhanna
Mongo, I find it hard to believe that it's a "special", and like I said above, I've been in this area a lot lately. I just took my screw out, it's not Machine threads, rather, more like a lag bolt, or large sheet metal bolt.
I compared it to a 5/16 lag bolt in my hardware bin. Almost identical, my lag bolt threads were just a little coarser.
jhanna
denton county, tx
2jhanna is offline
post #18 of 19 Old 07-17-2020, 08:31 AM
Dale M.
Generally metric bolts and nuts are pretty much standard and available in most auto parts and hardware stores..... IF needed to get online.
http://belmetric.com
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Dale M. is offline
post #19 of 19 Old 07-19-2020, 08:18 AM Thread Starter
Mongo01tj
Mongo01tj's Avatar
2j, thank you. My leak appears to be coming from inside the cover...I have a feeling this is going to exceed my abilities.
Mongo01tj is offline
