Missing bolt - JeepForum.com
 2Likes
post #1 of 19 Old 07-15-2020, 03:02 PM Thread Starter
Mongo01tj
Mongo01tj's Avatar
Missing bolt
I just bought my 01 tj and I'm missing the bolt on the transmission directly across from the oil drain plug. I'm admittedly terminology deficient. I would load a picture but I haven't figured that out yet.
Can someone tell me what size it is and where to get a replacement please?
Thank you!
Mongo01tj is offline
post #2 of 19 Old 07-15-2020, 04:17 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
pretty much need more info / photo of where it goes
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #3 of 19 Old 07-15-2020, 07:36 PM
mukluk
mukluk's Avatar
It'd also help if you would fill out your vehicle profile so we knew what transmission we're talking about.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 19 Old 07-15-2020, 09:23 PM Thread Starter
Mongo01tj
Mongo01tj's Avatar
I can't post pics yet. I added a pic to my gallery of the bolt. I don't know which transmission I've got. Think it's a n nv3550.
Pic is not my jeep.
post #5 of 19 Old 07-15-2020, 09:54 PM
mukluk
mukluk's Avatar
The bolt shown in your gallery is one of the clutch dust cover plate to bellhousing bolts. Those come in two sizes, so it'll either be an M8x2.12x16 or an M12x1.75x50. If the one missing is the very bottom one circled in the picture, that's the M8 bolt.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #6 of 19 Old 07-16-2020, 07:37 AM Thread Starter
Mongo01tj
Mongo01tj's Avatar
Thank you!!
post #7 of 19 Old 07-16-2020, 07:59 AM Thread Starter
Mongo01tj
Mongo01tj's Avatar
Of course, it's a discontinued part. Any idea where to find one? Google is pretty empty...
post #8 of 19 Old 07-16-2020, 08:14 AM
Dr. Internet
For all of your fastener needs:
McMaster-Carr
https://www.mcmaster.com/screws/hex-...hread-size~m8/
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #9 of 19 Old 07-16-2020, 08:25 AM
mukluk
mukluk's Avatar
A quick internet search turned up this bolt which seems to match the size and thread pitch: https://www.gmpartsgiant.com/parts/g...-11508154.html
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 19 Old 07-16-2020, 08:31 AM
BlueFl.Wrangler
Supporting Member
your local hardware store should have them
Winston Churchill
post #11 of 19 Old 07-16-2020, 08:42 AM
mukluk
mukluk's Avatar
M8x2.12 is not a common thread pitch that you're likely to find in a hardware store. Normally you'll only find M8x1.0 or M8x1.25 bolts.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #12 of 19 Old 07-16-2020, 11:49 AM Thread Starter
Mongo01tj
Mongo01tj's Avatar
It's a discontinued part from Chrysler. After further research, the GM part is self tapping. Next call will be to a salvage yard. Do I even need it? Uhg?
post #13 of 19 Old 07-16-2020, 12:07 PM
2jhanna
Maybe I'm off-base here, but since there's nothing life/death about this bolt, plus the bell housing being aluminum, and the hole is a through-hole, how bout running the closest tap though there and appropriate size bolt.
Sure beats running all over town, mail order, and junk yard.
Edit, I just realized I typed mail order, I guess I'm old.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #14 of 19 Old 07-16-2020, 12:29 PM
mukluk
mukluk's Avatar
How many box tops are needed plus postage and handling?
Andy-WhiteTJ and 2jhanna like this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #15 of 19 Old 07-16-2020, 01:23 PM Thread Starter
Mongo01tj
Mongo01tj's Avatar
It's not a through-hole. The two on either side are, but the lower one isn't. Threads into the housing. I agree, not sure how important it is, but I am seeing a seep of fluid from that spot. I've cleaned everything I can reach to determine if it's the rear main seal, which is my suspicion.
