Metalcloak Front Track Bar Life Expectancy? - Page 2 - JeepForum.com
 3Likes
post #16 of 22 Old 11-17-2016, 01:37 PM
squirrelrocket
I've had mine on for about 2 years and 12,000 miles and the heim still seems solid and tight. I live in the muddy rust belt so I regularly use WD40 to clean all my joints then shoot them with some motorcycle chain oil to help prevent corrosion.
Only issue I had was the bolt that goes through the the heim. I torqued it to 150ft lbs as per instructions with red lock tight. It still came loose so I just cranked it with a breaker bar to what seemed like an unhealthy amount of tight. I would still prefer a double shear mount like the rear has though.
squirrelrocket is offline
post #17 of 22 Old 11-17-2016, 07:05 PM Thread Starter
jjvw
jjvw's Avatar
Metalcloak found this thread and is sending me a new rod end. That should address the issue for at least as long as the old one lasted. Hopefully longer. Thanks Jon!
Ross and 88hatchy like this.
2003 Rubicon
jjvw is online now
post #18 of 22 Old 11-18-2016, 07:46 AM
rouxbicon
Sweeet! My MTRk's haven't lasted as long as I hoped. Now I hope Goodyear finds this thread and sends me some new ones...
'03 red Rubi
rouxbicon is offline
post #19 of 22 Old 11-18-2016, 07:50 AM Thread Starter
jjvw
jjvw's Avatar
I'm still investigating my options, but I really do appreciate the replacement.
2003 Rubicon
jjvw is online now
post #20 of 22 Old 11-18-2016, 11:58 AM
bobthetj03
bobthetj03's Avatar
I have 95k miles on my JKS TB. DD mostly with some occasional wheeling.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #21 of 22 Old 11-18-2016, 12:30 PM
rouxbicon
oh yeah, I was kidding around, that was pretty cool of them. Will at Metalcloak was good to me, too, when I cross-threaded and stripped out the flag nut at the axle end while installing my track bar. I sheepishly asked for another flag nut on my dime, but he sent one out no charge.
'03 red Rubi
post #22 of 22 Old 11-18-2016, 09:41 PM
88hatchy
I have about the same number of miles (15,000) on my MC track bar that was installed in October 2014, and it was tight when I removed it a month ago. To be fair, the QA1 heim that was installed in a different location on the same Jeep, at the same time, seems to be signififcantly tighter than the joint on the track bar.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
