Measuring ring gear backlash--at the heel, or the pitch diameter - JeepForum.com
 2Likes
  • 1 Post By Jonny Jeep
  • 1 Post By Jerry Bransford
post #1 of 5 Old 10-23-2019, 12:22 AM Thread Starter
Guy_Van_Horn
Here's something I ran into recently. While checking the backlash on my differential ring gear, I found a difference between measuring it on the heel of the tooth with a dial indicator, vs. at the center of the tooth profile (approximate pitch diameter) using a test indicator. In searching online, most of the how-to's seem to show people checking it at the heel of the ring gear with a dial indicator. I get why people do it this way, since it's easier to check at the heel, and nearly impossible to check with a dial indicator at the pitch diameter. However this seems to me to be wrong since that is not the theoretical diameter where the gear meshes with the pinion, i.e., the pitch diameter. The diameter at the heel is larger than the pitch diameter and checking it there would give a larger backlash reading. I admit, it isn't a huge difference (about .001"), but when you are shooting for a backlash from only .006" to .010", that small amount is significant.
Where do you check the backlash on you differential ring gear?
Sent from my SM-G920V using Tapatalk
Guy_Van_Horn is offline
post #2 of 5 Old 10-23-2019, 04:46 AM
Jonny Jeep
Jonny Jeep's Avatar
FSM shows the heel being used to check backlash and that's what I did. As you state, it's near impossible to do it anywhere else.
mukluk likes this.
Jonny Jeep is offline
post #3 of 5 Old 10-23-2019, 10:09 AM Thread Starter
Guy_Van_Horn
It's near impossible to do anywhere else with a dial indicator. It's quite easy to do on the pitch diameter with a test indicator.
post #4 of 5 Old 10-23-2019, 12:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It doesn't matter, the ring gear moves all parts of the gear teeth equally so it doesn't matter where it's measured. But most, probably 99.999%, would use a dial indicator so they'd use it on the heel.
arg0413 likes this.
Jerry Bransford is online now
post #5 of 5 Old 10-25-2019, 10:36 PM
CSP
The distance that the ID of the gear moves at xx degrees of rotation is smaller than at the OD of the gear.
CSP is offline
