manageable level of rust - JeepForum.com
 4Likes
post #1 of 29 Old 07-11-2019, 10:03 AM Thread Starter
dbowman
dbowman's Avatar
Hey guys!
Was just hoping someone with more knowledge than me could step in with the semi limited view of pics I was sent for an out of state purchase. Is this level of rust to the frame manageable or try to look elsewhere? Seems hard to pass up for the price at the moment.
dbowman is offline
post #2 of 29 Old 07-11-2019, 10:04 AM Thread Starter
dbowman
dbowman's Avatar
Zero idea why they upload upside down so I apologize for that.
dbowman is offline
post #3 of 29 Old 07-11-2019, 10:23 AM
222Doc
222Doc's Avatar
pics wont show enough to really give any type of good idea( what you see looks fair, but its what you DONT see). These frames tend to rust from inside out. by the time its seen on the outer its well gone. Me i would say rust is a deal breaker on a used vehicle that you plan to keep. its better to spend 2x on the jeep to get one that is nearly rust-less. then to get one that may need frame off resto , that will cost 5x more then its worth.
someone painted the under side not to long ago to make it LOOK better. as well they painted over rust, makes it worse.
222Doc is offline
post #4 of 29 Old 07-11-2019, 11:26 AM Thread Starter
dbowman
dbowman's Avatar
Thank you! I'm always worried about what people or dealers gave done in order to cover the rust up. The value of these unlimited rubicons blows my mind so trying to find one with limited rust within a reasonable price range has become quite an ordeal!
dbowman is offline
post #5 of 29 Old 07-11-2019, 11:55 AM
bparsel
Holy crap you Southwest guys crack me up. That rust is NOTHING to worry about.
bparsel is offline
post #6 of 29 Old 07-11-2019, 01:48 PM
fastblack
Yeah, that thing would be advertised “rust free” around here.
Sent from my iPhone using Tapatalk
fastblack is offline
post #7 of 29 Old 07-11-2019, 02:52 PM Thread Starter
dbowman
dbowman's Avatar
I guess price is whats really getting me. She only wants 14k for an 06 unlimited rubicon with 105k miles. clear title, cant find anything wrong in the pics besides that rusting. Everything else I'm seeing just from dealers are at least 20k.
dbowman is offline
post #8 of 29 Old 07-11-2019, 03:47 PM
2jhanna
Rust doesn't look too bad to me, but Do some searching. 05 and 06 pcm problems, especially with auto trans
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #9 of 29 Old 07-11-2019, 04:22 PM Thread Starter
dbowman
dbowman's Avatar
I have thanks to a previous post of mine! Thank you for checking! We actually have another 06 same make and model in the family as well. Nothing yet pcm wise on this one or the one we own but definitely prepared for that nightmare haha.
dbowman is offline
post #10 of 29 Old 07-11-2019, 04:46 PM
mukluk
mukluk's Avatar
Just a little crusty around a couple of the holes, but doesn't look too bad to me. The only spot that would have me mildly concerned is center bottom halfway between the rear control arm mount and the belly skid; it looks bubbled and without checking in person you can't tell for certain if it's just on the outside or has come through from inside. It's fairly safe to say you should expect the bottom inside of the frame to look like the rusty areas around the side frame holes.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #11 of 29 Old 07-11-2019, 05:08 PM Thread Starter
dbowman
dbowman's Avatar
If I receive this is there a solid way to put a hold to the spread? Just through coverups?
dbowman is offline
post #12 of 29 Old 07-11-2019, 05:18 PM
mukluk
mukluk's Avatar
Clean the inside of the frame the best you can to remove salts and loose scale/debris, then use your choice of rust converter, encapsulator, or frame saver product and topcoat. Lots of threads on the subject, I solved my rust issues by moving south where it's dry (mostly).
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #13 of 29 Old 07-11-2019, 05:34 PM Thread Starter
dbowman
dbowman's Avatar
Thank you! I’ll research. Reaching 110 this week for a couple days here in Cali so I was figuring it would help a bit hahah
dbowman is offline
post #14 of 29 Old 07-11-2019, 11:23 PM
daredevil95
Junior Member
daredevil95's Avatar
That's not rust, that's good. I would be more concerned about the 14K price tag. To much IMO, you could buy a very nice sport for about 7K and put another 3K into the sport and now you know what you have and most likely way beefier then the Rubicon while built to your specs....although starting of with a Rubicon would be nice in a perfect world but, not for 14K on a 06. imo
daredevil95 is offline
post #15 of 29 Old 07-12-2019, 09:00 AM
bparsel
I dont know where you are seeing $7k Unlimiteds....most unlimiteds in decent shape are $10k minimum. If they are clean with lift and tires etc I regularly see them in the $12-14k range with many asking up to $17k. They are getting more rare by the day.
bparsel is offline
