Maintenance to do while Tranny is out? - JeepForum.com
post #1 of 7 Old 08-22-2015, 11:09 AM Thread Starter
wwbeards
I just pulled my transmission out of my 2002 jeep wrangler 4.0L and I'm wondering if there's any maintenance i should be doing while I have it out. The thought of a main seal crossed my mind but I haven't pulled off the pressure plate to see if you can actually get to them from there or you need to pull off the oil pan. I pulled the tranny to replace the clutch so all of that is already getting replaced while I'm in there.
This is my first time pulling a transmission and all I needed to take care of was the clutch but I'm sure there's something else that needs to be done while I'm in there. Any suggestions are appreciated.
wwbeards is offline
post #2 of 7 Old 08-22-2015, 11:14 AM
Jeepsr4me
look and see if there is a freeze plug that you can only get to with pressure plate off...
Jeepsr4me is offline
post #3 of 7 Old 08-22-2015, 12:05 PM
TJ4Jim
The access the RMS is via the oil pan so that's not something that has to be done while the trans is out. I would do a fluid change in the trans and transfer case while it is out and replace the throw out fork spring clip, other than that there is not much to do other than inspecting the joints on each drive shaft. If you are re-using the flywheel do not have it re-surfaced as it has a convex surface, just clean it up.
TJ4Jim is offline
post #4 of 7 Old 08-22-2015, 12:08 PM
Jeepsr4me
if the RMS is leaking it is way easier to do without the trans up there so yes it is something I would do if it needed to be done.
post #5 of 7 Old 08-22-2015, 02:16 PM
chaz360
Rear main is the two-halves style, whatever the modern rubber equivalent is of the old rope-style seals. Can do that anytime with tranny in or not, drop the oil-pan, pull rear main and get ya a "sneaky pete" tool to wiggle out the upper half. Make sure that your input shaft seal isn't leaking (Tranny fluid on the clutch is never good). Easy as removing the bolts from the input shaft housing (where the throw-out bearing slides-on) and popping off the seal out from the back of the housing with a pry tool.
chaz360 is offline
post #6 of 7 Old 08-22-2015, 05:22 PM
btn
btn's Avatar
Transmission mount isolator?
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #7 of 7 Old 08-22-2015, 06:22 PM
GilaMtnJeep
GilaMtnJeep's Avatar
It's not a "maintenance" item, but you may want to look into relocating the breather vent to a higher location for the trans and t-case. Much easier while it's out.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
maintenance , rear main seal , transmission
