Luk clutch kit warning - Page 9 - JeepForum.com
post #121 of 162 Old 10-04-2012, 03:59 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by silverjeep
this is on scary thread, I know my clutches days are numbered and I'm not sure which clutch to get. Time to switch to an auto.
Sachs, or go to NAPA and have a look inside the box before you pay.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #122 of 162 Old 10-04-2012, 04:02 PM
greg_kulosa
greg_kulosa's Avatar
Just order a luk clutch, and if the throwout bearing is plastic, get a new one from NAPA.
I did mine a few weeks ago, and just scuffed my flywheel with sandpaper. It did not need to be replaced.
The luk clutch and pressure plate that they are shipping is fine. It's just the throwout bearing that might need to be replaced.
greg_kulosa is offline
post #123 of 162 Old 10-29-2012, 08:38 AM
TroubleNEO
TroubleNEO's Avatar
Did my clutch back around the beginning of July with a new Luk Gold kit. The last few weeks or so I've been getting that metallic scratching or scraping sound indicative of a bad TO bearing on startup.
Seems like lots of other people have been having issues with the TO bearings in the new LUK kits.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #124 of 162 Old 11-13-2012, 08:08 AM
LocknRoll
Man I'm glad I found this thread.
Getting set to do a clutch job on my 03 Rubi. Suspect lots of wear left but getting some angry noises from the throwout bearing.
Was all set to buy a LUK kit from one of the "trusted" ebay vendors. Emailed them and they confirmed that the kit they are selling has the cheap stamped/plastic bearing.
Gonna check with my local Napa/Carquest dealers to see which version they are selling.
Gerry...Did LUK ever get back to you with any comment?
Gotta wonder, if they have cheaped out on the throw out bearing...what have they done to cut costs on the pressure plate, pilot bearing and friction material???
Cheers
03 5 spd Black TJ Rubicon, Stock for now
LocknRoll is offline
post #125 of 162 Old 11-17-2012, 03:30 PM
olaverty
olaverty's Avatar
Just went through this myself. Checked the Luks at every Napa around, Pep Boys, etc. Plenty in stock, in blue boxes, yellow boxes, napa boxes, no matter what had the plastic bearing. Decided to just go with Sachs at Oreillys.
olaverty is offline
post #126 of 162 Old 12-11-2012, 03:50 PM
Hammond_Egger
I will add my story regarding LUK kits to the mix...
Bought a set last year from Ebay for $95 shipped (it had the crappy plastic bearing) to keep as a spare.
Fast forward a year, now that my stock throwout bearing is getting noisy, I am starting to think about changing it out.
I was by Pep Boys today and decided to see what they had in stock...
Pep Boys #1 Plastic Bearing (Made in Mexico on the box)
Pep Boys #2 Jackpot! (Made in Mexico on the box)
Everything else in the kit was EXACTLY the same, but it had the metal bearing (NTN C01437CA..made in the USA!).
Needless to say, I bought the kit...and then returned it with the plastic bearing
It still looks to be hit or miss...
Hammond_Egger is offline
post #127 of 162 Old 12-11-2012, 04:59 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I read a recent "review" of the new throwout bearing a week or two ago by a Jeeper on one of the forums. From his comments, perhaps the new throwout bearing is better than we thought... that the plastic (actually something stronger like Delrin) content apparently doesn't serve a key structural purpose. The personal opinion of the reviewer essentially was that he was blessing it and not to be worried that it won't hold up. I personally haven't seen the new style so I can't comment myself.
Jerry Bransford is online now
post #128 of 162 Old 12-11-2012, 05:29 PM
Hammond_Egger
I had seen that review also Jerry. I did not have a real problem with the plastic part (most likely Delrin like you said). but the actual bearing part was really thin and cheap. Not enough feedback for me to try it!
post #129 of 162 Old 12-12-2012, 07:27 AM Thread Starter
JeffBowser
JeffBowser's Avatar
Let me remind everyone, 9 pages in, that it wasn't so much the plastic that concerned me originally. It was merely an easy identifier. What the issue was was the ID of the bearing was too large, and it destroyed itself. Metal bearings at the time did not seem to have an out of spec issue.
JeffBowser is offline
post #130 of 162 Old 05-17-2013, 05:43 PM
jr03
Just had this same thing today. Luk clutch kit for a 2.5l the throw out bearing ID was .01 to .02" to large and could wobble around on trans shaft. Using one from local parts store that's all metal with correct inside diameter.
I am using a luk composite bearing on my own jeep and that one was correct size
jr03 is offline
post #131 of 162 Old 05-17-2013, 06:08 PM
gargyle
I have a LUK clutch in my 2003. It's been in for 2 years, seems to be okay other than is kind of heavy on the clutch pedal.
gargyle is offline
post #132 of 162 Old 05-21-2013, 10:49 AM
jeepn012
jeepn012's Avatar
Recieved this "Luk" kit from Amazon(Sols Brake Supply).
http://www.amazon.com/Clutches-Flywh...=AU5XWW1ZAEYCZ
It shows up in a beat up USPS priority mail box. The pressure plate/disc are shrink wrapped separately from the cheapo plastic throwout bearing which was simply wrapped in bubble wrap.
Pretty sure I got hosed. Gonna go by NAPA on the way home to see what they have.
1990 YJ - 96 to 03 My first. She will be missed.
2004 TJ - 03 to 11. Old Faithful. I will have another TJ one day.
2007 JKU - SOLD
2005 LJ - In the mail, hope I like it. Everybody's doin it, here is the build:
jeepn012 is offline
post #133 of 162 Old 05-21-2013, 11:24 AM
sjones26573
sjones26573's Avatar
My Luk is still going strong. My transmission, however, is not.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #134 of 162 Old 05-21-2013, 10:10 PM
JeepZJlover
If you look on rockauto there picture description has the all steel tb and yellow box wether that's what they ship or not is a different story. On a side note didn't Jeep use sachs as an original supplier?
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #135 of 162 Old 05-23-2013, 12:33 PM
JeepZJlover
Tried ordering a luk clutch kit today has plastic throwout bearing anybody having issues with this kit besides the fitment? Thinking about sending it back and getting a Sachs? Opinions how you guys sach clutches holding up?
My clutch is too hard to push in; should I replace the clutch master slave cylinder? Willey JK Wrangler Technical Forum 0 03-04-2012 09:55 PM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 06:49 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 09:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
