Luk clutch kit warning - JeepForum.com
post #1 of 162 Old 07-17-2012, 09:04 AM Thread Starter
JeffBowser
JeffBowser's Avatar
Replace the whole works, including flywheel two weeks ago with the Luk standard kit. The throw-out bearing was out of spec, and vibrated. By yesterday it had destroyed the pressure plate, damaged the release fork, and snapped off the pivot bearing.
I don't know if this was one of a kind, or if Luk has gone too cheap in China, but this has been one expensive clutch replacement. We went Sachs this time, and let me tell you - the throw-out bearing alone is a pound heavier and there is no plastic on it.
JeffBowser is offline
post #2 of 162 Old 07-17-2012, 09:18 AM
Terdar
I replaced my clutch on my '06 at the beginning of the year with a LUK kit and the TO bearing that was in the box was wrong, no way it would connect to the Jeep's fork. I ended up getting a Precision brand TO bearing from advanced and that started to rattle after two months.
I had to pull the trans again and replaced it with a Crown TO bearing. So far it's holding up.
Terdar is offline
post #3 of 162 Old 07-17-2012, 09:21 AM
UnlimitedMatt
I wonder what may have changed with Luk? I installed one in our Cherokee a year and a half ago with no issues yet (knock on wood).
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
UnlimitedMatt is offline
post #4 of 162 Old 07-17-2012, 09:24 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
I've always used Luk and never had any problems.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #5 of 162 Old 07-17-2012, 09:44 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've done 3 or 4. The first ones I would agree with you. The last one had a TO bearing that did nothing to induce any warm and fuzzies.
It was pretty scary at how lightweight it was made and how much plastic it had and I'm not an anti-plastic guy at all.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 162 Old 07-17-2012, 09:47 AM
sjones26573
sjones26573's Avatar
Err... I just ordered one yesterday. Should I get a different TO bearing? Any other issues?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #7 of 162 Old 07-17-2012, 09:47 AM
TheBoogieman
Distubed Jeepaholic
The ones I did were over 8 years ago.Maybe they got cheap or I got lucky.
post #8 of 162 Old 07-17-2012, 09:48 AM
HurricaneRZA
HurricaneRZA's Avatar
With that in mind, would you continue using them or would you use a different brand?
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #9 of 162 Old 07-17-2012, 09:51 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't have enough miles on that rig to know. I trust Luk, so I hope I can trust they know what they are doing. The problem with this issue is how much work it is to find out.
If I knew of a better version and could get my hands on it, I'd really consider doing so if the one you get doesn't look that robust.
I am Savvy
mrblaine is offline
post #10 of 162 Old 07-17-2012, 09:52 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I should have phrased that better. I've done 3 or 4 this year.
I am Savvy
mrblaine is offline
post #11 of 162 Old 07-17-2012, 09:54 AM
HurricaneRZA
Oh, gotcha... Yeah I need to do my clutch soon. Stories like this always make me nervous beforehand
post #12 of 162 Old 07-17-2012, 09:58 AM
rkymtn05
rkymtn05's Avatar
X2 on the Sachs. I could get a cheaper price locally on it than the luk at the shop near my last job and they came highly recommended by the mechanic there. I don't know if there is anything necessarily better about them but, I've had no problems with it for almost a year.
All that is necessary for the triumph of evil is that good men do nothing.
rkymtn05 is offline
post #13 of 162 Old 07-17-2012, 10:14 AM Thread Starter
JeffBowser
JeffBowser's Avatar
I wish I had stopped to take a picture. The Sachs throw-out bearing was so obviously beefier and differently shaped than the Luk one that I'm left wondering if Luk is sticking the wrong bearings in the kit.
post #14 of 162 Old 07-17-2012, 10:20 AM
MemorEsto
Mine was about 3 years ago and never had a problem.
President of Acer Offroad A♦A♣A♠A♥
The bigger the stinger, the smaller the wiener
MemorEsto is offline
post #15 of 162 Old 07-17-2012, 10:21 AM
srlbotanical
srlbotanical's Avatar
I just put the napa premium clutch kit in my 97 TJ. It's made by Luk, has Luk stamped right on it. The TO bearing looked and felt identical to the one I took off...
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
My clutch is too hard to push in; should I replace the clutch master slave cylinder? Willey JK Wrangler Technical Forum 0 03-04-2012 09:55 PM
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 06:49 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 09:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
