Low power 99 Wrangler 4.0, compression? - JeepForum.com
post #1 of 10 Old 07-29-2010, 10:00 PM Thread Starter
TJMistress
Runs smooth as silk at idle, just no power over 2000 rpm. It acts like the timing is off but I checked to make sure the timing chain didn't skip a tooth, its fine. After rechecking my compression with the proper extension for my gauge the compression reads 118-125. Is this too low? Fuel pressure at the rail is good. It has new plugs, wires, cap and rotor.
TJMistress is offline
post #2 of 10 Old 07-29-2010, 10:12 PM
wushaw
Rockin jeep
wushaw's Avatar
Check your cat, it could be clogged. Your compression is fine.
wushaw is offline
post #3 of 10 Old 07-29-2010, 11:42 PM
ElementX
ElementX's Avatar
2x on clogged cat
'98 TJ Sport
ElementX is offline
post #4 of 10 Old 07-30-2010, 08:56 AM Thread Starter
TJMistress
I'll check the cat soon. Does anyone know what an acceptable compression building rate is? All six cylinders followed this basic pattern.
Stroke 1: 60psi
Stroke 2: 90psi
Stroke 3: 110-115 psi
Strokes 4-6: 115-125 psi
post #5 of 10 Old 07-30-2010, 12:14 PM
wushaw
Rockin jeep
wushaw's Avatar
Compression spefications per Mitchell is 120-150. And your checking it fine. Check the cat now.
wushaw is offline
post #6 of 10 Old 07-30-2010, 06:09 PM Thread Starter
TJMistress
Exhaust is flowing fine. Here are the next three things that in my mind should be checked. Injectors, coil, and or 02 sensors.
Any comments?
post #7 of 10 Old 07-30-2010, 06:58 PM
wushaw
Rockin jeep
wushaw's Avatar
Did you remove the cat and see if the power comes back above 2k? Or did ya just see if it was flowing?
wushaw is offline
post #8 of 10 Old 07-30-2010, 08:42 PM Thread Starter
TJMistress
I took the cat and muffler out to make sure nothing was floating around and loose inside. I put it on the shop vac to see if it was flowing (it was) and then reinstalled it and put a pressure gauge in the upside O2 sensor. It stayed at zero at idle and around 1/2 pound at 3-4000 rpm. It instantaneously spikes with quick acceleration at 4 psi but is right back under 1 psi.
I guess I coulda taken it out for a spin but didn't really feel like putting the skid plate and trans mount back on, not to mention letting my redneck show through suburbia as I made my way to the freeway for a test. Since there was no back pressure in front of the cat I assumed it was fine. If there is a reason for a road test its still not back together as I have broken studs and stripped bolts from one end to the other on this thing.
post #9 of 10 Old 07-30-2010, 09:40 PM
wushaw
Rockin jeep
wushaw's Avatar
It is off and it can't hurt, it will also rule the cat out for sure.
wushaw is offline
post #10 of 10 Old 09-28-2010, 11:23 PM
spooled
What was your outcome on this? I am having similar issues.
spooled is offline
catalytic converter , loss of power , low power
Full compression in front, no compression in rear Caceman YJ Wrangler Technical Forum 5 05-20-2009 07:00 PM
Need Power!! 91 Wrangler 1blackjeep YJ Wrangler Technical Forum 15 04-04-2009 06:46 AM
97 Wrangler has no power. HELP! gardner TJ Wrangler Technical Forum 7 08-01-2008 10:00 PM
Power locks on an '04 wrangler limecoconut TJ Wrangler Technical Forum 19 06-09-2006 10:52 AM
More Power on a Wrangler TexasJeepGuy TJ Wrangler Technical Forum 60 06-25-2003 10:06 PM
