low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 25 - JeepForum.com
 4Likes
post #361 of 382 Old 04-13-2015, 01:31 PM
BamaJeepman21
BamaJeepman21's Avatar
Originally Posted by mudb8 View Post
3" below axle center and 1" above the stock upper frame mount puts you about 19" @ ride height with a 2.5 lift.
Damn alright. So I'm still looking at a 10" shock then if I use the 5" below centerline. The Fox 2.0 IFP's are 16.75" collapsed.
-Jack
BamaJeepman21 is offline
post #362 of 382 Old 04-30-2015, 12:11 AM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Another mount pattern today....
3.5" lift, OME n67L rear shock 14.5/24.5". Set at 5" uptravel, 15 3/4" spring free length.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #363 of 382 Old 09-08-2015, 07:27 PM
Ljcrawler05
Any chance you've got a set of lower mounts for an lj so I can actually run the ome long travels I've got heading my way? I've looked into this thread a bunch of times over the last couple years, but it's now something I want to try and do. I'm really not trying to lift my jeep anymore, but I want to be able to run a decently long travel shock with stock upper mounts. I definitely want to pay you for your materials and your time, I just don't have the means of making them myself. Thanks mud!
Ljcrawler05 is offline
post #364 of 382 Old 10-31-2015, 01:50 AM Thread Starter
mudb8
mudb8's Avatar
Got another batch made.
mudb8 is offline
post #365 of 382 Old 12-19-2015, 12:08 PM
Stop being a
I ended up just shifting the lower mounts outboard,
just used the stock mount I cut off and welded it to a plate that got welded to the control arm brackets..
no more spring bucket, exhaust or tank rubbing...
Brilliant!
Stop being a is offline
post #366 of 382 Old 01-20-2016, 03:12 PM
91rrc
Got any of those left that you would be willing to part with?
91rrc is offline
post #367 of 382 Old 11-07-2016, 11:50 AM
plara4
Mudb8, have u been getting my messages? They don't show up in my sent box
plara4 is offline
post #368 of 382 Old 11-07-2016, 12:01 PM
plara4
Mudb8, have you been receiving my messages. They don't show up in my sent box.
Well just email me so we can continue where we left off. ([email protected]) Get a hold of me quick so I can delete this comment lol
plara4 is offline
post #369 of 382 Old 07-23-2017, 06:45 PM
shadowk99
Any of these still available ?
shadowk99 is offline
post #370 of 382 Old 07-23-2017, 08:38 PM
Hosejockey61
Do your own, it's easy if you have a welder.
Hosejockey61 is offline
post #371 of 382 Old 07-24-2017, 08:34 AM
shadowk99
I probably will does any one change the orientation of the upper shock mount when relocating the axle side to the back of the control arm bracket ?
post #372 of 382 Old 01-05-2020, 03:53 PM Thread Starter
mudb8
mudb8's Avatar
Crazy how time goes by..... still doing the same old stuff!
Sent from my SM-G965U using Tapatalk
mudb8 is offline
post #373 of 382 Old 01-07-2020, 12:28 PM
Fargo
Fargo's Avatar
Do you ever move out the bottom bracket without doing the full tower? If so, how do you handle the top mount?
I have the Nth degree shock shifters, but when I used the included top mount I lost an inch of upward travel and had to add bumpstop. So I quit using the shock shifters and went back to stock location. I'd be curious at how you handle the top mounts without adding the towers.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #374 of 382 Old 01-07-2020, 12:39 PM
TJnBC
SOooooo when you gonna ship me some of those brackets? @mudb8
2006 LJR...the madness begins again
TJnBC is offline
post #375 of 382 Old 01-24-2020, 07:12 AM
jeepbro's
Do you sell these or similar lower rear mounts? Looking at running 14.5" collapsed length shocks with upper bar pin elimators on the rear of an LJ I just picked up that will have 2" spacers for now, eventually/soon 2.5" springs. I already have the shocks from a friend that had outboarded his rear and they are new bilstiens valved for a tj but I don't want to cut into the frame on this jeep at this time.
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
Nth Degree/AEV Rear shock shifters sduncan TJ Wrangler Technical Forum 5 08-30-2009 10:41 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 10:43 PM
bds shock shifters TSWRA TJ Wrangler Technical Forum 4 08-15-2005 02:10 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 12:45 PM
