Low frequency Buzz at 1100 rpm forward or reverse. Please advise. - JeepForum.com
post #1 of 2 Old 10-05-2008, 11:55 AM Thread Starter
Medo
Medo's Avatar
When I barely hit the gas I get this buzzing noise at 1100 RPM then it goes away in forward or reverse. It sounds like sheet metal or maybe the dash vibrating right around the firewall. My TJ runs great other than that one sound, any ideas?
Medo
By the way it's an Automatic.
The definition of insanity is doing the same thing over and over again and expecting different results.
Medo is offline
post #2 of 2 Old 10-05-2008, 04:06 PM Thread Starter
Medo
Medo's Avatar
So, no possible explanations or experience with this problem from anyone?
Nada, Zilch, Finito...........
Medo
Medo is offline
Water Pump: Forward or Reverse Flow? zener6 TJ Wrangler Technical Forum 3 04-02-2009 10:18 PM
Buzz Buzz goes the Fuse Block losfelizwheelz YJ Wrangler Technical Forum 8 10-30-2007 01:50 PM
In reverse my inlaws Jeep suddenly stops, forward is fine though, Why??? 93Renny YJ Wrangler Technical Forum 8 07-21-2007 10:51 AM
Forward or Reverse Axles? PDX_XJ TJ Wrangler Technical Forum 4 07-12-2005 11:31 AM
Axle Movement - forward/reverse DanH YJ Wrangler Technical Forum 3 12-04-2002 03:49 PM
